[postgis-users] using && operator
Jan Saalbach fire at dubmosphere.de
Fri Aug 20 07:47:03 PDT 2010
Thank you Aman for your detailed answer. I understand why it did not
work in the first place now. And yes, I need to learn SQL properly.
Regards,
Jan
Zitat von Aman Verma <aman.verma at mcgill.ca>:
> Hi,
> It looks like you're having a little bit of trouble with the SQL.
> That is understandable though, your problem is a little tricky,
> because it requires you to nest a query.
> You should first note that it is not possible to have two FROM
> statements in a single query. Start by breaking down the problem
> into individual parts:
> 1) You need to collect both geometry columns each into a single
> collection. You can do this with two separate queries:
> select st_collect(pkt) as first_set from pktbsp1;
> select st_collect(pkt) as second_set from pktbsp2;
> 2) Now, you need to find a way to have the result of both these
> tables in a single place. This is done by nesting the two above
> queries into another query.
> select x.first_set, y.second_set from
> (select st_collect(pkt) as first_set from pktbsp1) x, -- I could
> have used JOIN instead of a comma.
> (select st_collect(pkt) as second_set from pktbsp2) y;
> If you're having trouble figuring out how the query nesting works, I
> suggest brushing up your SQL at sqlzoo.net.
> 3) Now, you can compare these two geometries. So the full query is:
> select x.first_set && y.second_set from -- Note that st_intersects
> (x.first_set,y.second_set) would be fine too
> That will return a single row with a single column: t or f.
> Hope that helps,
> aman
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Jan Saalbach
> Sent: August 20, 2010 10:02 AM
> To: PostGis Users List
> Subject: [postgis-users] using && operator
> Hi List,
> how do I check if two 3d-point sets overlap? I see the && operator
> should be able to compare the bounding boxes, but how do I do it? I
> can not get the && or ST_Intersects function to work. Here is what I
> am trying to do:
> SELECT ST_Collect(pkt) FROM pktbsp && ST_Collect(pkt) FROM pktbsp2;
> pkt are GeometryColumns filled with 3dpoints. pktbsp and pktbsp2 are
> the respective tables.
> How can I check this?
> Reagrds,
> Jan
> postgis-users mailing list
