[postgis-users] WKT Raster - geos version error while running rtpostgis.sql
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Aug 23 12:28:45 PDT 2010
Hi Tyler,
Is this the same geos you are using when compiling PostGIS? WKT Raster is indirectly rependent on geos via PostGIS.
Pierre
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of Tyler Erickson
>Sent: 20 août 2010 18:55
>To: postgis-users at postgis.refractions.net
>Subject: [postgis-users] WKT Raster - geos version error while running rtpostgis.sql
>I am trying to run WKT Raster's rtpostgis.sql against a database, but am
>encountering in the following error:
>psql:/usr/share/postgresql/8.4/contrib/rtpostgis.sql:32: ERROR: could not
>load library "/usr/lib/postgresql/8.4/lib/rtpostgis.so": libgeos-3.2.0.so:
>cannot open shared object file: No such file or directory
>I would have expected to see libgeos-3.2.2.so mentioned instead of
>libgeos-3.2.0.so since I specified the GEOS version location during the
>configure step.
>~/src/wktraster$ ./configure
>--with-postgis-sources=/home/terickson/src/postgis/postgis-1.5.1
>--with-gdal=/usr/local/gdal/1.7.1/bin/gdal-config
>--with-geos=/usr/local/geos/3.2.2/bin/geos-config
>Other potentially relevant info:
>OS: Ubuntu 9.10
>PostGIS was built using GEOS 3.2.2
>$ psql -d $WKTRASTER_TEMPLATE -c "SELECT POSTGIS_FULL_VERSION()"
> postgis_full_version
> POSTGIS="1.5.1" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
>2009" LIBXML="2.7.5" USE_STATS
>(1 row)
>I do have GEOS 3.2.0 installed on my system... but I was trying to use the
>latest version.
>Any idea why the WKT Raster script is trying to access GEOS 3.2.0 instead of
>the specified version 3.2.2?
>- Tyler
>View this message in context: http://old.nabble.com/WKT-Raster---geos-version-error-while-running-
>rtpostgis.sql-tp29496374p29496374.html
>Sent from the PostGIS - User mailing list archive at Nabble.com.
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
