[postgis-users] Problem trying to clip multipolygons in one file from multipolygons in another.
L Bogert-O'Brien dlawbob at ncf.ca
Wed Aug 25 09:39:53 PDT 2010
I am trying to clip the water polygons (y2006.ca_wat_cbf_clp wat)
from the census tract polygons (y2006.ca_ct_cbf ct) and store the
clipped census tracts in another table (y2006.on_ct_cbf_clp).  The
following is the latest query I tried:
INSERT INTO y2006.on_ct_cbf_clp (ctuid, cmauid, pruid, the_geom_4269)
(SELECT ct.ctuid, ct.cmauid, ct.pruid,
         COALESCE(ST_MULTI(cleangeometry(
                           ST_DIFFERENCE(ct.the_geom_4269,
wat.the_geom_4269))),
                  ct.the_geom_4269)
   FROM y2006.ca_ct_cbf ct LEFT OUTER JOIN y2006.ca_wat_cbf_clp wat
     ON ct.the_geom_4269 && wat.the_geom_4269
  WHERE ct.pruid = '35'
  ORDER BY ct.ctuid);
When I left the COALESCE out, I did not get any geometry field for
the census tracts that did not have bounding boxes intersecting with
bounding boxes of water.  The ctuid, ct.cmauid and ct.pruid fields
were transferred, but the geometry field was empty.  Now, however, I
get 1 to 3 rows for each census tract in my new table.  When there
are three rows, one is the original geometry, another is the water
portion and the third is the land portion (i.e. the only part I want
to be in left in the new file).  When there are two rows, this
appears to be for areas where bounding boxes intersect, but there are
no actual water pieces intersecting the census tract.  Thus the
original geometry is entered on two lines, whereas I only want it
once.  When there is one row for a census tract, it is just what I
want, the original geometry for the areas that have no water parts
intersecting them.
Can anyone suggest a fix?
Note that I also got the following warnings output when running this query:
NOTICE:  LWGEOM_gist_joinsel called with incorrect join type
NOTICE:  The input type <NULL> is not supported
..[snip]... about 200 more of these <NULL> warnings
Query returned successfully: 3781 rows affected, 64619 ms execution time.
Thanks for your help.
Loretta
