[postgis-users] pgsql2shp fails
Paragon Corporation
lr at pcorp.us
Thu Aug 26 23:20:21 PDT 2010
Denis,
I don't have the latest svn version handy, though I think the version I have
has the latest pgsql2shp in it and its about a week or 2 old.
I tested with dumping out a spatial table from my 2.0 database and it worked
fine. It could be an issue with parameters. (though the error you describe
is a bit bizarre since gid is not needed to dump out a spatial table)
Can you give us the following bits of information
1) pgsql2shp -- with no args -- what does the version number say
Mine reads -- the below
RCSID: $Id: pgsql2shp.c 5450 2010-03-22 19:38:14Z pramsey $ RELEASE: 2.0
USE_GEOS=1 USE_PROJ=1 USE_STATS=1
2) What command line switches are you using - an example would be nice
I tested with this
pgsql2shp -f C:\cities -h localhost -p 5439 -u postgres postgis_test20
cities
and worked fine for me
3) Version of PostgreSQL you are running
4) Output of the below
SELECT postgis_scripts_released()
mine reads
2.0 r5793
5) Your operating system
Thanks,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Denis
Rykov
Sent: Thursday, August 26, 2010 10:51 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] pgsql2shp fails
Hi, just updated to 2.0svn and it seems that new pgsql2shp fails with new
db, but works with 1.5 ones, pgsql2shp from 1.5 works fine with both
keeps saying "column "gid" does not exist" even on fresh tables where SELECT
AddGeometryColumn was done
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100827/9691ec92/attachment.html>
