[postgis-users] Can save but not retrieve using Hibernate+PostGIS+JTS
dave.potts at pinan.co.uk dave.potts at pinan.co.uk
Fri Aug 27 00:26:19 PDT 2010
Hi
Have you checked in the postgres database logs?
There might be a clue in there as to why it is not working
> El Thursday 26 August 2010, Paulo Angelo escribió:
>> Hi Ppl,
>>   I'm getting a weird problem. I can save a Geometry type through
>> Hibernate
>> but I can't retrieve it.
>>  WKTReader fromText = new WKTReader();
>>  Geometry geom = fromText.read("POLYGON((0 0,0 3,3 3,3 0,0 0))");
>> Session session = dao.newSession();
>> Transaction tx =  dao.beginTransaction(session);
>> Query q = session.createQuery("select f from Geometries f");
>> List list = q.list();
>> Poligono to = (Poligono) lista.get(0);
>> dao.commitTransaction(session, tx);
>> to.setPoli(geom);
>> System.out.println(to.getPoli().toString());  // Apears "POLYGON ((0 0,
>> 0
>> 3, 3 3, 3 0, 0 0))"
>> dao.alterar(to, null, null);
>>  // I can see via SQL that it saves correctly
> And have you checked that it appears in the database after the commit?
> Maybe
> the commit is not really commited (can't see why, though).
>> // Now, retrieve
>> list = q.list();
>>  // Get a *NullPointerException*, because to.getPoli() is null
> Have you tried debugging step by step checking that all variables are ok?
> Are
> you sure that "to" is not null instead of to.getPoli()?
> Have you tried using Criteria instead of hql? Maybe it is a conversion
> problem
> between geometry types.
> Could it be that closing/commiting the transaction is the problem? If
> hibernate didn't get all the data on one shot, closing the transaction
> makes
> hibernate unable to get more info from the database.
> Anyway, if you rollback a read-only transaction instead committing,
> hibernate
> goes faster.
> María Arias de Reyna Domínguez
> Área de Operaciones
> Emergya Consultoría
> Tfno: +34 954 51 75 77 / +34 607 43 74 27
> Fax: +34 954 51 64 73
> www.emergya.es
> postgis-users mailing list
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
