[postgis-users] install postgis on Linux x86_64 with PostgreSQL 9.0beta4
FISSELL at pitt.edu
FISSELL at pitt.edu
Fri Aug 27 10:02:38 PDT 2010
I am having an error doing make install for postgis.
This is a Linux x86_64 platform. I installed PostgreSQL 9.0beta4
> /usr/pgsql-9.0/bin/pg_ctl --version
pg_ctl (PostgreSQL) 9.0beta4
I installed postgres from rpms, eg
postgresql-server-9.0-beta4_1PGDG.rhel5.x86_64.rpm
I could do a src install if you think that would be better.
postgres installed in a combination of standard /usr dirs (eg /usr/share) and
/usr/pgsql-9.0/ dirs, (eg /usr/pgsql-9.0/include) (see pg_config command
below).
The postgis make install command errors out with this:
make[1]: /usr/pgsql-9.0/share/contrib/postgis-1.5: Command not found
There are also a bunch of "ignoring old commands" warnings.
(See below).
I assume some earlier step in the install that was supposed to put
postgis-1.5 in the contrib dir failed.
The README.postgis file says I should run make install as user postgres, so
I did. Why is that necessary ? Does the install procedure actually
invoke psql ?
Most of the postgres files are installed as user root.
I tried the install as root and that also failed.
Unfortunately I was not able to run make check because I had problems
installing CUnit due to rpmlib dependencies.
any help most appreciated
thanks
Kate
> ./pg_config
BINDIR = /usr/pgsql-9.0/bin
DOCDIR = /usr/share/doc/pgsql
HTMLDIR = /usr/share/doc/pgsql
INCLUDEDIR = /usr/pgsql-9.0/include
PKGINCLUDEDIR = /usr/pgsql-9.0/include
INCLUDEDIR-SERVER = /usr/pgsql-9.0/include/server
LIBDIR = /usr/pgsql-9.0/lib
PKGLIBDIR = /usr/pgsql-9.0/lib
LOCALEDIR = /usr/pgsql-9.0/share/locale
MANDIR = /usr/pgsql-9.0/share/man
SHAREDIR = /usr/pgsql-9.0/share
SYSCONFDIR = /etc/sysconfig/pgsql
PGXS = /usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk
CONFIGURE = '--disable-rpath' '--prefix=/usr/pgsql-9.0'
'--includedir=/usr/pgsql-9.0/include' '--mandir=/usr/pgsql-9.0/share/man'
'--datadir=/usr/pgsql-9.0/share' '--with-perl' '--with-python'
'--with-tcl' '--with-tclconfig=/usr/lib64' '--with-openssl' '--with-pam'
'--with-krb5' '--with-gssapi' '--with-includes=/usr/include'
'--with-libraries=/usr/lib64' '--enable-nls' '--disable-thread-safety'
'--with-ossp-uuid' '--with-libxml' '--with-libxslt' '--with-ldap'
'--with-system-tzdata=/usr/share/zoneinfo'
'--sysconfdir=/etc/sysconfig/pgsql' '--docdir=/usr/share/doc' 'CFLAGS=-O2
-g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mtune=generic -I/usr/include/et'
'CPPFLAGS= -I/usr/include/et'
CC = gcc
CPPFLAGS = -I/usr/include/et -D_GNU_SOURCE -I/usr/include/libxml2
-I/usr/include
CFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
-I/usr/include/et -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv
CFLAGS_SL = -fpic
LDFLAGS = -L/usr/lib64
LDFLAGS_EX =
LDFLAGS_SL =
LIBS = -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lgssapi_krb5 -lz
-lreadline -ltermcap -lcrypt -ldl -lm
VERSION = PostgreSQL 9.0beta4
bash-3.2$ make install
make -C liblwgeom
make[1]: Entering directory `/usr/local/pkg/postgis-1.5.1/liblwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/usr/local/pkg/postgis-1.5.1/liblwgeom'
make -C postgis
make[1]: Entering directory `/usr/local/pkg/postgis-1.5.1/postgis'
Makefile.pgxs:17: warning: overriding commands for target `install'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:99: warning: ignoring old
Makefile.pgxs:63: warning: overriding commands for target `installdirs'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:147: warning: ignoring old
Makefile.pgxs:82: warning: overriding commands for target `uninstall'
/usr/pgsql-9.0/lib/pgxs/src/makefiles/pgxs.mk:171: warning: ignoring old
make[1]: Leaving directory `/usr/local/pkg/postgis-1.5.1/postgis'
make -C loader
make[1]: Entering directory `/usr/local/pkg/postgis-1.5.1/loader'
make[1]: Leaving directory `/usr/local/pkg/postgis-1.5.1/loader'
make -C utils
make[1]: Entering directory `/usr/local/pkg/postgis-1.5.1/utils'
chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
profile_intersects.pl test_estimation.pl test_joinestimation.pl
make[1]: Leaving directory `/usr/local/pkg/postgis-1.5.1/utils'
PostGIS was built successfully. Ready to install.
make -C postgis install
/bin/mkdir -p '/usr/pgsql-9.0/lib'
'/usr/pgsql-9.0/share/contrib/postgis-1.5'
make[1]: *** [installdirs] Error 127
make: *** [postgis-install] Error 2
