[postgis-users] Very slow intersection
Birgit Laggner
birgit.laggner at vti.bund.de
Thu Dec 2 06:05:08 PST 2010
Hi Ted,
I am not sure if this would help very much, but I always make an inner
join on the bounding boxes of the geometries (as a sort of filter), like
this:
create table countyShp as select cty.gid,
st_intersection(cty.the_geom,cst.the_geom) as the_geom from
countyShpWideBound as cty inner join uscoast as cst on cty.the_geom &&
cst.the_geom where st_intersects(cty.the_geom,cst.the_geom);
Are you sure, you have a gist-index on your geometries?
But, with tables with more than 500000 rows, I get comparable run times
like you.
Regards,
Birgit.
On 01.12.2010 15:30, Ted Rosenbaum wrote:
> Hello,
> I am looking to take the standard Tiger/Line Shapefile of US counties,
> which includes major waterways in the border of counties (especially
> an issue around the Great Lakes) and truncate the county polygons to
> exclude the area beyond the coastline. I tried creating a new table
> based on two tables from two shapefiles -- one of the county polygons
> (from tiger/line) and one of the US coastline-- using the following code:
> countyShpWideBound as cty, uscoast as cst where
> I have indexes on the geometries in both tables, but this is taking
> hours to run (I had a power failure after about 6 hours and it was not
> finished running).
> This seems like it should be a very simple and common issue, so I
> wanted to see if people could let me know either what I am doing wrong
> in my SQL statement or of alternative approaches to excluding areas of
> the coast from US county boundaries.
> Thanks.
> Ted Rosenbaum
> Graduate Student
> Department of Economics
> Yale University
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101202/768cf633/attachment.html>
