[postgis-users] osm2pgsql error, out of memory, though i use -s
Torsten Mohr
tmohr at s.netic.de
Thu Dec 2 12:29:09 PST 2010
Hello,
> I suggest that you ask on one of the OpenStreetMap lists (osm-talk or
> osm-dev) as people there will be more familiar with osm2pgsql.
correct, i did not think of this. Next discussions i'll put there.
> You will have to start over. Some information on osm2pgsql performance
> can be found here:
> http://www.geofabrik.de/media/2010-07-10-rendering-toolchain-performance.pd
> f but the bottom line is, more memory (along with a proper setting of -C as
> has been suggested already) will definitely help.
Thanks for that hint. I have changed the command line to use more cache with
-C 4000. This is just a guess, i hope it works.
I imported other OSM planet files before and never got that error. It seems
it is purely related to the amount of data?
Thanks for all the hints i got on this list,
Torsten.
