[postgis-users] PLPGSQL, parametrizing a column name and a GEOMETRY
Sebastian E. Ovide
sebastian.ovide at gmail.com
Fri Dec 3 06:51:52 PST 2010
Thanks Charles,
The USING did the trick
EXECUTE 'UPDATE ' || quote_ident(table_name) || ' SET FIELD= $1' USING
geometry
On Fri, Dec 3, 2010 at 2:00 PM, Charles Galpin <cgalpin at lhsw.com> wrote:
> Sebastian, you might want to try something like
> EXECUTE 'UPDATE ' || quote_ident(table_name) || ' SET FIELD=' || CAST('''
> || CAST(geometry as text) || ''' as geometry)
> hth
> charles
> On Dec 3, 2010, at 6:59 AM, Sebastian E. Ovide wrote:
> > Hi All,
> > I'm creating a PLPGSQL which has 2 parameters: a geometry and a table
> name.
> > The query is something like UPDATE table_name SET FIELD=geometry.
> > I've tried to use EXECUTE like this
> > EXECUTE 'UPDATE '||quote_ident(table_name)||' SET
> FIELD='||geometry::geometry
> > but I'm getting an error in the geometry: (HINT: Could not choose a best
> candidate operator. You might need to add explicit type casts.)
> > any ideas ?
> > Sebastian E. Ovide
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101203/f04bba24/attachment.html>
