[postgis-users] Loading spatial point from text file
Sairam Krishnamurthy kmsram420 at gmail.com
Mon Dec 6 12:06:53 PST 2010
Hey Kevin,
Thanks for your reply. Will this be faster than updating the spatial points
after loading the lat/lon values? I will sure try this out in a while. But
if this is going to slower that that things wont be easier for me. What is
your opinion?
Thanks,
Sairam
On Mon, Dec 6, 2010 at 12:00 PM, Kevin Neufeld <kneufeld.ca at gmail.com>wrote:
>  You could create a BEFORE INSERT TRIGGER on your table that modifies the
> records you are inserting by populating the spatial column using the
> NEW.long and NEW.lat values.
> Alternatively, you mentioned that you didn't even want long/lat in the
> database at all.  In that case, as part of your loading script, you could
> try to:
> - create a temp dummy table as the target for your COPY command
> - place a RULE on the dummy table to redirects INSERTs into a table for all
> your data
> - run the COPY and drop the dummy table.
> i.e., this works.
> CREATE TABLE foo (pt geometry);
> CREATE TEMP TABLE foo_tmp (long double precision, lat double precision);
> CREATE RULE foo_tmp_insert_rule AS
>    ON INSERT TO foo_tmp
>    DO INSTEAD
>    INSERT INTO foo (pt) VALUES (ST_MakePoint(NEW.long, NEW.lat));
> -- You would use your COPY command here to insert records
> INSERT INTO foo_tmp (long, lat) VALUES (-56.57647, -64.7647);
> DROP TABLE foo_tmp CASCADE;
> SELECT ST_AsText(pt) FROM foo;
>          st_astext
>  POINT(-56.57647 -64.7647)
> (1 rows)
> Cheers,
> Kevin
> On 12/6/2010 8:43 AM, Sairam Krishnamurthy wrote:
> All,
> I have a test file that contains the data to the loaded to the spatial
> table I have. The table structure is <lat,lon,data1,data2,spatialPoint>.
> Sample data in the txt file : <-64.7647, -56.57647, 1234548, 1221312>.
> So I want to load the table from this text file. I use the COPY query
> below.
> *COPY "table_name" (lat,lon,data1,data2) FROM 'FILE' DELIMITER ','*
> But the problem is I am not able to update the spatialPoint using copy
> query. So for now I am loading the lat,lon,data1,data2 fields and then
> update the spatialPoint using a separate query similar to one below:
> *UPDATE "table_name" SET "spatialPoint" =
> ST_SetSRID(ST_MakePoint(lat,lon),4326) WHERE "spatialPoint" IS NULL*
> My question is, is there a way to avoid the second query so that I can also
> load the spatialPoint in the COPY query?
> Also I initial dint want to have lat,lon in the table and have only the
> spatialPoint field. Because of the above problem I was forced to have
> lat,lon fields in the table. Someway to achieve this will help me a lot.
> Thanks,
> +1 612 859 8161
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101206/b308f35f/attachment.html>
