[postgis-users] Select junctions in linear dataset
Kevin Neufeld
kneufeld.ca at gmail.com
Mon Dec 20 20:56:50 PST 2010
Selecting the start and endpoint in a fully-noded linear dataset has
always worked for me to get the junctions. Why does it not give you the
desired result? What's happening?
-- Kevin
On 12/16/2010 1:52 AM, Thomas Kouk wrote:
> Hi all,
> I am newbie in postgis. I have a linear dataset (road network) and I
> want to select the junctions (in order to count them and maybe isolate
> them in a seperate point table). ST_StartPoint and ST_EndPoint do not
> give me the desired result, no matter how I combine them. Is there
> another way or a function that I could use?
> Alternatively I could create a loop in php to examine each feature and
> to find for each end-point if there is other feature in zero
> distance... however I think that this would be a really painfull and
> long lasting procedure, especially in case of dense data. There should
> be a simpler way...
> Thanks,
> Thomas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101220/ee45cc72/attachment.html>
