[postgis-users] Traverse set distance along a multiline?
Aren Cambre
aren at arencambre.com
Mon Dec 27 21:50:39 PST 2010
Thank you. Now my shp2pgsql conversion results in a PostGIS table with an
SRID. I then ran this query to reproject the data into a new table:
*INSERT INTO txdot_roadways_3081_transform*
*SELECT [all other fields go here], ST_Transform(the_geom, 3081) as the_geom
*FROM txdot_roadways;*
Loading into qgis, the map now looks like a correct projection for taking
planar (?) measurements. Previously the state looked as if it
was stretched horizontally, but I guess that's to be expected if
longitudinal lines don't bend.
Thanks again to both of you for helping with this. It never occurred to me
how easy it can be to reproject GIS data.
Aren
On Mon, Dec 27, 2010 at 6:15 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Right, use 4269, that's a good NAD83-geographic-coordinates number.
> Import with shp2pgsql -s 4269 and go from there.
> P
> On Mon, Dec 27, 2010 at 3:54 PM, Aren Cambre <aren at arencambre.com> wrote:
> > Brent and Paul,
> > Thank you for your help!
> > So here's my (new) dilemma--my PostGIS table doesn't appear to have a
> > projection specified, and I am not clear how to get to one.
> > I don't think it has a projection because this table's corresponding
> entry
> > in the geometry_columns table has -1 for the srid column.
> > This ShapeFile's PRJ file has this:
> GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
> > I'm not seeing a clear match between this and any projection.
> > Some Google searching suggests this may be 4326, but I'm not sure about
> > this. And if I modify geometry_columns and import the PostGIS table into
> > QGis, I get this QGis error:
> > 1 cursor states lost.
> > SQL: CLOSE qgisf0
> > Result: 7 (ERROR: current transaction is aborted, commands ignored until
> > end of transaction block
> > If I revert that field back to -1, the error goes away on next import.
> > When I imported using shp2pgsql, I didn't use the -s switch. I presumed
> it
> > would catch the projection automatically.
> > I'm at a loss to know what to do next. I guess I need to figure out what
> the
> > true SRID of this data is before I can do any re-projections?
> > Aren
> > On Mon, Dec 27, 2010 at 12:22 AM, Paul Ramsey <pramsey at opengeo.org>
> wrote:
> >> You need to do your analysis in a projected coordinate system, not
> >> geographics.
> >> CREATE TABLE my_new_texas_roads AS
> >> SELECT ST_Transform(the_geom, 3081) as the_geom, other_attributes
> >> FROM texas_roads;
> >> EPSG:3081 should be a good coordinate system for working with your Texas
> >> data.
> >> http://spatialreference.org/ref/epsg/3081/
> >> Not that the units are meters, so perform the appropriate linear
> >> transformations when looking for mile markers.
> >> Paul
> >> On Sun, Dec 26, 2010 at 4:35 PM, Aren Cambre <aren at arencambre.com>
> wrote:
> >> > I am trying to determine mile markers along Texas highways. My
> starting
> >> > point is the ShapeFile TxDOT Roadways 2010
> >> > at http://www.tnris.state.tx.us/datadownload/download.jsp. I've used
> >> > shp2pgsql to get it into a PostGIS 1.52-enabled Postgres 9.01
> database.
> >> > I naively thought I could just figure out the number of miles per unit
> >> > of
> >> > latitude and then traverse each roadway, one mile at a time,
> >> > using ST_Line_Interpolate_Point. However, predictably, the more
> >> > "longitudinal" a route, the more error it shows when I compare my
> >> > calculated
> >> > mile markers to what Google Maps shows.
> >> > Again, this is because I was using a consistent ratio of degrees to
> >> > miles,
> >> > so any route E-W component introduces errors.
> >> > So here's the question--does PostGIS allow any way to traverse a route
> a
> >> > set
> >> > distance at a time? Specifically, is there a way I can traverse a
> route
> >> > a
> >> > mile at a time and then record the points at the end of each mile?
> >> > I reviewed the functions available
> >> > at
> http://postgis.refractions.net/documentation/manual-1.5/reference.html and
> >> > am not seeing anything clear.
> >> > In case it matters, the SHP's PRJ file says NAD83.
> >> > Aren Cambre
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101227/9afef7da/attachment.html>
