[postgis-users] Null value when inserting large linestrings or multilinestrings in windows
Alberto Almagro Sotelo
almagro at celtaprix.es
Thu Dec 30 03:52:53 PST 2010
SOLVED: Thank you SO MUCH Nicklas,
If I query
SELECT ST_NPoints(lineaepsg4326) FROM rutageometrias
I get 1945! So the geom is stored there hehe, it was a problem of the
lenght of the string in Windows pgAdmin.
Thank you again!
El jue, 30-12-2010 a las 12:33 +0100, Nicklas Avén escribió:
> Hallo
> By visualizing in pgadmin, do you mean that you see a long string of
> numbers and letters representing the binary form of the geometry. If
> that string is too long pgadmin won't show it.
> You say that you have this problem in your app, but the only symptom I
> see you are describing is that you dont see it in pgadmin. Is this
> right?
> To check if the pgadmin limit is what you are talking about try running:
> SELECT ST_Length(the_geom) from thetable where
> ST_NPoints(the_geom)>1050;
> Then you should see that those geometries with more than 1050 points
> have a length which means that they are there. You just don't see that
> string.
> This we should have in the FAQ. I think it is one of the top 10
> questions at this list.
> HTH
> Nicklas
> On Thu, 2010-12-30 at 11:00 +0100, Alberto Almagro Sotelo wrote:
> > Hello,
> > When I try to insert/update a linestring/multilinestring with more than
> > 1050 points in PostgreSQL/PostGIS installed on windows, and try to
> > visualize it after in pgAdminIII I see an empty value instead of the
> > geometry. This does not happen if the linestring/multilinestring has
> > less of 1050 points and also if I insert only points.
> > I use eclipse IDE, Java, Maven, Tapestry, Spring and Hibernate Spatial.
> > When I run the test fase in maven it passes all the tests, including the
> > ones which insert or update linestrings or multilinestrings and after
> > the app retrieves them from db to check their values... this only
> > happens when I run my app in a webapp server like jetty or tomcat and
> > only in windows! I have tried in Windows Server 2003 x86, Windows Vista
> > 64bits, and Ubuntu Linux with PostgreSQL 8.3, 8.4 and 9.0 versions and
> > PosGIS 1.3.3, 1.3.5, 1.4.0, 1.4.2 and 1.5.2 versions... and I only get
> > the error on windows.
> > I could run my app on linux only but I need to deploy it on a Windows
> > Server 2003 system...
> > IMPORTANT: When I say that I use Hibernate Spatial, it's true, but
> > thinking that this could be the problem I substituted the Hibernate
> > Spatial code in that use case with JDBC and the result was exactly the
> > same.
> > I need some help... tell me if you need more info about the error...
> > The table definition is this:
> > CREATE TABLE rutageometrias
> > idrutageometrias bigint NOT NULL,
> > lineaepsg4326 geometry,
> > lineaepsg23029 geometry,
> > "version" bigint NOT NULL,
> > CONSTRAINT pk_rutageometrias PRIMARY KEY (idrutageometrias),
> > CONSTRAINT enforce_dims_lineaepsg23029 CHECK (st_ndims(lineaepsg23029)
> > = 2),
> > CONSTRAINT enforce_dims_lineaepsg4326 CHECK (st_ndims(lineaepsg4326) =
> > 2),
> > CONSTRAINT enforce_geotype_lineaepsg23029 CHECK
> > (geometrytype(lineaepsg23029) = 'MULTILINESTRING'::text OR
> > lineaepsg23029 IS NULL),
> > CONSTRAINT enforce_geotype_lineaepsg4326 CHECK
> > (geometrytype(lineaepsg4326) = 'MULTILINESTRING'::text OR lineaepsg4326
> > IS NULL),
> > CONSTRAINT enforce_srid_lineaepsg23029 CHECK (st_srid(lineaepsg23029)
> > = 23029),
> > CONSTRAINT enforce_srid_lineaepsg4326 CHECK (st_srid(lineaepsg4326) =
> > 4326)
> > WITH (
> > OIDS=FALSE
> > ALTER TABLE rutageometrias OWNER TO postgres;
> > And the pg_log this (seems to be OK):
> > 2010-12-30 10:41:48 CET LOG: ejecutar S_1: BEGIN
> > 2010-12-30 10:41:48 CET LOG: ejecutar <unnamed>: INSERT INTO
> > rutageometrias(idrutageometrias, lineaepsg4326, lineaepsg23029,
> > "version") VALUES ($1, $2, $3, $4)
> > 2010-12-30 10:41:48 CET DETALLE: parámetros: $1 = '0', $2 =
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
> > 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
> > DEEC3F892041F8AE3D8F9D075241F0E4CBA53F89204149D345A79D075241BB1E24EB3F892041951BF9B29D075241A929B58A3E8920411EAE70D69D0752417DA8EBFE3D8920415FE8D3ED9D0752411EF1248A3E892041EE6F16E29D07524113FE72B83D892041CA236CF99D07524113FE72B83D892041CA236CF99D0752410EB97C9E3C892041547B4B119E075241AAF9D6B23A89204179FD4D409E07524105A820DC368920410C2E48929E075241A718C91E34892041E866A0D89E07524173199C79328920419CAF0AFC9E075241C3F3BFA631892041442B60139F075241F2EE3F5C31892041108C47729F075241A0179810318920416729FCD09F0752416FDE6D0B31892041BF5BC93BA0075241CC16460631892041570464A6A0075241B4350E4B318920416BF2D2D5A0075241C4B95849318920417E4B29F9A0075241E223418F3189204163D136F9A007524142D58A96348920414D538077A007524145C7EA8336892041BC62C224A0075241D2F727E3378920412F32E201A00752411104237038892041C393E7E99F0752411104237038892041C393E7E99F0752414C00BCB738892041F3EFEDAE9F075241427B622F3889204105653F7F9F075241EECDF35F3789204107A4B54F9F0752410B05F08F3689204199B8362C9F07524175494E78358920412EA0002C9F075241779F0E1934892041065B134F9F07524158E239B93289204190EB307E9F0752414D38C6E5318920415EC6C3A19F0752419685D25831892041F6C726B99F0752410102000000320000003A730510318920410275D4DC9F07524190F38756318920416FF687E89F075241B328C6E131892041DF4D7BF49F075241F379FF6C32892041FAB8D300A0075241FED2C8F4328920414205283CA0075241BC8389C6338920415FDECE53A00752418B47F899348920416717A130A0075241B26DB6DE34892041C163AE30A007524107ED00DD34892041C8BC0454A0075241492FF89534892041E89E5883A00752419660554E348920418B8506A7A00752415852A24C34892041D3542ACAA0075241898D609134892041AF854DE2A00752419FCC196335892041DF1776E2A0075241B7D6423436892041F56B44EEA0075241648E6909378920416BC28DA7A0075241EED1460C378920414C48546CA0075241084882F335892041433D9C83A0075241FF05C9213589204108AB7383A007524184F0FBD834892041F45721A7A0075241FF05C9213589204108AB7383A0075241696A832335892041603EB85FA0075241594CD46835892041A123036CA0075241B2174468358920417CE5A877A007524123D66B693589204170C4C55FA0075241EF1FC925358920417D23BC30A0075241F7D08F9A348920412CB86324A007524159DB0F543489204157919330A00752416AC9940D34892041EE
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
> > 892041754B1FC3A4075241E47D91CF288A2041FB8B4966A40752416F69BB5A528A2041A97405B1A30752411DB9B7E75A8A20415DE98EF0A107524152AEA7CD798A2041606A5721A10752419E2278C38B8A204199CF7F70A2075241C1763A587E8A2041ED6FDE36A30752413F50A1047A8A20410999F754A2075241DC4BB7547D8A204161534898A1075241F8942298808A20414CBE7EC8A1075241EB6F6793838A2041A8CAD256A2075241AFDB9D5D848A20412CA0ABD9A20752419922F3CE838A20410B3A482CA3075241709AE0B3828A20419E26F172A30752412C1FAFDE818A204199443FBAA30752411C06E995818A20413CA138F5A3075241CB1735D7818A2041201C3B54A40752415078DBFC808A204194CFBE05A5075241C1A1787E7E8A20412B8718ABA50752411C73182D7E8A2041859A3CAFA6075241FFAB7FF77B8A204189C74D31A7075241FA2B731F7B8A2041304D70B3A7075241AE9E055F7B8A2041FCAAFB35A8075241AEED4B17878A2041F073B6AEA80752412C52CBCEC68A2041AB0B15E1A607524119A89ED9198B20415FAA654BA6075241098489697E8B2041B1DC7507A5075241D911F195C68B2041A7B49953A3075241AA0A8CCDCE8B2041EEA665EAA2075241A7FFBEE5CF8B2041976BF6DEA20752411F705FF3C98B20414805C89DA10752414FA125E5C58B2041AA3FC6C7A007524101020000003200000059F41E71C38B20418887CDAFA00752410A53913FC18B2041F4995CDEA00752412A973096F58B204147D96CCEA2075241732FCD1B4F8C20417713D9D8A3075241B89C2C84CD8C2041CF264D7FA40752411475E14C628D2041C3CB7C7DA5075241106E8BEF128E2041E8ECECA4A6075241FBD35AC8E38E2041A70E6CDEA7075241D963BF54C28F2041774DA939A8075241C9C69FBDAB902041E192CAD6A907524187DAE5DF94912041C2110980AB075241ED3483BF599220414A198458B10752419B1BA8BB0A932041511DC2E4BB07524193E07AF199932041C69D7706CA075241DF73FD0CF39320411985B04DD3075241B75436EA299420419689AA44D9075241F6147DEFF2932041F864B013DB075241D9195D04CF9320419594430BD30752414F91A64880932041F1F2F6D1C907524126A32D820C932041C7A92FA0BE0752411627A5A089922041263B5121B50752412C81BA141B922041A904FC90AE075241BECD2795D291204163F0CF31B1075241842C0B70DB912041354CA7DAB9075241204A14BEF6912041CE11206DBF07524158DCD8BD029220418BB79FC2BF0752419A431547069220415F684922C0075241EE8E272B08922041BA38E08CC00752419DF596B50B92204198AE77A5C0075241CAA80CCC0C922041934B2DBDC0075241BB2D5E840C92204159D5DAE0C00752414DF8843B0C922041226D061C
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
> > 6909C7EE5E86204183588F71B80752418CA7CF4F7E862041B338CA60B307524196CCB19799862041E1603143AE0752412087BED5A28620419B660D75A9075241F70A96689B862041010723DFA40752414E2169889B862041917DD247A207524145B45002A2862041B44974E7A3075241469819B29F862041F78AD795A6075241F6215670A38620411D8E3041A8075241CC246E01A8862041AD3D01D5A9075241CE395CB4B9862041F93C73E8AA075241623B1A1EC8862041AB980A2BAC07524199873AEDCE8620412D194F8BAC075241566F5BE8D48620418F88CC1AAD07524166D63E2FD886204193A46D1BAD075241D9AA94D0D6862041D890A832AD0752415E4831E0DC86204164DA8817AC075241A83A9DA7E28620415774EF2BAB07524132C981D1DE86204183B41272AB075241669567DCD98620412EEAAC69AC075241FC5260A4DF8620417EDB575AAB07524166934FB9C38620415227E4ACAC0752415E427FE1B18620416C3BAF01A9075241F406B6CDA7862041995EEA59A8075241CD717BE3AB862041D41FED95A80752416875D506AE862041A47EC7A6A9075241E1923740AE8620418E0F8893AA075241D605AA67AD862041FBE2B521AB07524191F8E767A58620419D4F36CAAC075241EFD3ACB5A3862041930610FEAD075241D5DDC3A59C8620414F83394BAD075241D52A345896862041A90262A8AD0752412F30989790862041DC323D06AE075241D488AD418786204190EDE314AF075241568F914F7886204199C0E73BB3075241DCFC2E226C862041B4D8799AB607524142AAC8026F862041CD32363EB9075241187609BA6E86204199446279B90752415D4EAEA1708620412205499DB907524169A7E1566F862041ECC05616B80752418131F5996F862041601A6B51B807524137C94DAF708620411F763481B80752410BDA955572862041B7704B46B8075241951C96B66E8620414A447A0FB4075241A1F4801E6D862041AAE64322B30752418F9DB0766F8620415432067FB50752413BFB2D326E862041D7067A0EB90752418627E2C756862041D6707263BD0752412F6ED8563C86204186A9D265BC075241010200000032000000D418DABE068620416D126E25B807524159C99EC0FA85204181E5ADACB7075241C9D1359FFE852041E23B10B5B6075241267A836E028620419DF2AAFCB607524154FCF1E504862041934AC2CDB6075241BDDED25B04862041A72851AAB607524133EB505CFB8520413C662061B6075241280DC8F1ED85204162207A1CB7075241248C34F5B9852041D5773C82B3075241D291B28185852041FFD30732AE075241FA1A1C7D708520414FA56EFEAD07524159971DAC6C8520410C13F8D9AD0752417CCD12DC6B852041AA29ACB6AD075241FC001B086B852041A82A80E5AD075241344E6ED5688520
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
> > 0752411DD7AA29CD762041FC649684670752411DD7AA29CD762041FC649684670752410F2C983DCB762041668776BF670752419E72C69CCC7620414EEBFA9B67075241EA4FDBB3CD7620411A566BA8670752413B2DAF9800772041401BD47C6B07524163BF8CBF6D772041D64497567307524199C0B7D407782041CC8B7C07780752416757AD03917820418579CF0B760752417EDFB501BA782041A91B816D75075241A087B48FBA782041E69D393E750752411EE66D60B878204170E2D23D7507524155BA56A6B8782041DAB9DF3D75075241AF9012EAB8782041EEBD4D6D75075241840B2D74BC78204110272EA975075241F0586E3FEC782041990D139A75075241FCFAD5EE4379204114C35D04750752412F5A6120B979204174D9E23874075241C0DF2DE5497A20414A16269A79075241D180E426DD7A2041F4F68C1E840752415DB273636B7B2041CF50D8DA90075241CAD8D8A7047C2041C8CEBA3C9B07524126022BF3A77C2041DE799C7E9B075241335FD2101E7D204183171ADA860752419263FF3CB17D2041CCC58ACA75075241FEF98D0B0B7E20418D1C33475F07524181E900C95F7E204145255A0B4C075241B2021104057F2041E9FC8C1A46075241C196FEECBB7F204149290B5D4D075241010200000032000000215B96AD6B80204112171B9B5B075241B183EF591481204150E4685569075241FFAF7C8BA4812041E91B45EA74075241605F763DEE812041EDFB098A7B0752412593537CE881204117F98EF37B075241258350CFE6812041084DB9A47C075241E8639781E6812041E11596627D0752411A56B413E8812041E475B1D17E07524194C27A64E681204138DA52CA7F07524104CD4716E38120412591E26380075241AC7C2FECDD812041BA1137E07F075241CB41915DDD812041081A561B800752410ED5C7C9DF812041185484D98007524106551282E2812041D600421581075241487C5954E3812041ADE8C30981075241B59BD9B4008220418D0FED828307524186A03D4038822041510CD605870752410F2DC18E878220414FA290758A0752410EB874A4C5822041A705CE408E07524123E1F7F2CD8220412CB6EAF18B07524123A30D4DCE822041C08DDC2F8A0752414F701476CF822041758845C188075241A4808708D382204132E1194B88075241E4106299D3822041EFD2FEE0870752419A0E025CE08220413E8CF575890752415A0AA6F112832041EF6BAAE48D075241243FA8DC30832041A01D097690075241062F55AE31832041D8AAB25E90075241FC8F3A0A33832041A1BC2E9A9007524179662151368320414F0ACE9A90075241D387E754398320415C404348900752416110446E3A8320414A48A03C90075241A834C553398320410861266090075241D33FACAE37832041276B109B90075241A1BA8EAD
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
> > 2010-12-30 10:41:48 CET LOG: ejecutar S_2: COMMIT
> > 2010-12-30 10:41:48 CET LOG: ejecutar <unnamed>: SET SESSION
> > CHARACTERISTICS AS TRANSACTION READ ONLY
> > 2010-12-30 10:41:48 CET LOG: ejecutar S_1: BEGIN
> > 2010-12-30 10:41:48 CET LOG: ejecutar <unnamed>: /* load
> > es.celtaprix.gisapp.model.ruta.Ruta */ select ruta0_.idRuta as
> > idRuta11_0_, ruta0_.activa as activa11_0_, ruta0_.descripcion as
> > descripc3_11_0_, ruta0_.fecha as fecha11_0_, ruta0_.frecuencia as
> > frecuencia11_0_, ruta0_.nombre as nombre11_0_, ruta0_.subnombre as
> > subnombre11_0_, ruta0_.version as version11_0_ from Ruta ruta0_ where
> > ruta0_.idRuta=$1
> > 2010-12-30 10:41:48 CET DETALLE: parámetros: $1 = '0'
> > CHARACTERISTICS AS TRANSACTION READ WRITE
> > Thank you for your help in advance.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
