[postgis-users] st_equals strangeness
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jan 8 09:44:20 PST 2010
Paul Ramsey wrote:
> More to the point, it's a float32 box, not a double64 box. Your two
> points are in fact different, waaaaaay down deep into the precision of
> their 64-bit double coordinates. So deep in fact that the human
> readable decimal representations don't show it (look at the hexewkb
> output, and you'll see the differences, you should be able to do that,
> points are small enough to eyeball in hex).
> So when the 32-bit box is extracted from the 64-bit doubles, the
> points are identical at that level of precision and = returns true,
> while st_equals working against the doubles does not.
> P
Again, another demonstration as to why BOX2DFLOAT4s should never be used
for calculations and only for internal "within" checks :(
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
