[postgis-users] pgsql2shp usage
Chris Hermansen
chris.hermansen at timberline.ca
Mon Jan 11 13:09:51 PST 2010
Ok well it seems to me that your second step, namely pgsql2shp, is not
necessary if you have no use for a shape file in the end. So let's
focus on your osm2pgsql command
In your first e-mail, you said:
> I downloaded an OSM map file namely "india.osm.bz2".
> I transported it in PostgreSQL database "gis" with the command :
> ./osm2pgsql -m -d gis india.osm.bz2
> The above command resulted in the creation of the following tables filled with data in database "gis"
> gis=# \d
> List of relations
> Schema | Name | Type | Owner
> public | geometry_columns | table | anisha
> public | planet_osm_line | table | anisha
> public | planet_osm_point | table | anisha
> public | planet_osm_polygon | table | anisha
> public | planet_osm_roads | table | anisha
> public | polygon_oid_seq | sequence | postgres
> public | spatial_ref_sys | table | anisha
So what is wrong with this? Looks like your data is in the postgis database...
Anisha Kaul wrote:
> Hi,
> Many thanks to all of you for bothering to reply !!
> From Chris Hermansen
> > Anisha, why are you converting to shape file?
> I failed to load the map directly from the database !
> So I thought it will be a boostup for me if I manage to load the map
> from a shape file, and then I can go for the database reading !
> I didn't have any problem in loading a world map from a shape file
> directly downloaded from the internet, but I am facing problems when I
> convert the postgres data in a shape file and then try to load it.
> From Regina
> > Never worked with osm data, but since I created the .prj generator in
> > pgsql2shp, I can tell you it reads the srid of the geometry and looks up the
> > srtext in spatial ref and outputs that to the .prj file.
> > I suspect osm data is in Mercator not long lat. If you want your output to
> > be in long lat, you need to transform and use an sql statement
> > pgsql2shp -f "/path/to/filename" -h myserver -u apguser -P apgpassword
> > mygisdb
> > "SELECT field1 AS hs_num, field2...., ST_Transform(the_geom,4326) As
> > the_geom FROM planet_osm_line"
> I tried what u said as follows:
> ______________________________________________
> pgsql2shp -f ../data/myfile gis "SELECT *, ST_Transform(way,4326) As
> Output:
> Preparing table for user query... Failed: ERROR: AddToPROJ4SRSCache:
> Cannot find SRID (4326) in spatial_ref_sys
> Then With reference to this
> http://postgis.refractions.net/pipermail/postgis-users/2008-February/018486.html
> web page I executed the following in the postgres database
> gis=# SELECT UpdateGeometrySRID ('public', 'planet_osm_polygon','way',
> 4236);
> Output:
> ERROR: constraint "enforce_srid_way" of relation "planet_osm_polygon"
> does not exist
> CONTEXT: SQL statement "ALTER TABLE public.planet_osm_polygon DROP
> constraint enforce_srid_way"
> PL/pgSQL function "updategeometrysrid" line 53 at EXECUTE statement
> SQL statement "SELECT UpdateGeometrySRID('', $1 , $2 , $3 , $4 )"
> PL/pgSQL function "updategeometrysrid" line 4 at SQL statement
> I don't know what to do now, please guide !
> Regards,
> Anisha Kaul
> Hi-Tech Gears Limited, Gurgaon, India
> postgis-users mailing list
Regards,
Chris Hermansen · chris.hermansen at timberline.ca · skype:clhermansen
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.840.4625
Timberline Natural Resource Group Ltd · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
