[postgis-users] Huge query, out of memory
Nicolas Gillet - MARKET-IP nicolas.gillet at market-ip.com
Thu Jan 14 02:23:16 PST 2010
Hello,
I have a big shape file to process (about 300 Mo,  1.5 million records)
I have to aggregate the touching linestrings having the same attributes
therefore the best way I could find (with help of this mailing list) was to
aggregate all the linestrings with the same attribute and then splitting the
ones that don't touch.
Here is the query :
SELECT subQ.id, subQ.feattyp, subQ.frc, subQ.shieldnum, subQ.name, null,
(st_dump(merged_geom)).geom AS the_geom
FROM (
                SELECT MAX(id) AS id, feattyp, frc, MAX(shieldnum) AS
shieldnum, nw.name, ST_LineMerge(ST_Collect(the_geom)) AS merged_geom
                FROM nw
                WHERE nw.frc >= 0
                GROUP BY nw.name, nw.feattyp, nw.frc
) AS subQ;
This has worked fine on smaller shapes  but on this one I get an out of
memory error.
I used pgTune to change database default settings and the result is as
follow :
#custom_variable_classes = ''                   # list of custom variable
class names
default_statistics_target = 50 # pgtune wizard 2010-01-13
maintenance_work_mem = 120MB # pgtune wizard 2010-01-13
constraint_exclusion = on # pgtune wizard 2010-01-13
effective_cache_size = 1408MB # pgtune wizard 2010-01-13
work_mem = 12MB # pgtune wizard 2010-01-13
wal_buffers = 8MB # pgtune wizard 2010-01-13
checkpoint_segments = 16 # pgtune wizard 2010-01-13
shared_buffers = 480MB # pgtune wizard 2010-01-13
max_connections = 80 # pgtune wizard 2010-01-13
All the other parameters have their default values.
What can I do to run my script through this heavy shape files ?
Thank you
Nicolas.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100114/09fca8dc/attachment.html>
