[postgis-users] multilinestring/polygon display lookup questions
Jedrin
jrubiando at gmail.com
Thu Jan 14 21:51:12 PST 2010
Thanks,
I will try it at work when I get in tommorow. I had named the field
'poly' at a time when that's what it always was. I had ruby code that
assumed the geo field had that name and hadn't refactored the code
thus far.
I am still somewhat of a novice with postgis, and find it hard to find
advanced tutorials, thanks ..
On Jan 14, 2:35 pm, "Paragon Corporation" <l... at pcorp.us> wrote:
> Jedrin,
> This is one of the rare cases when you really need to use && directly
> instead of the embedded on in ST_Intersects.
> The reason its so slow is that your spatial index (assuming you have one),
> is on poly not that calculated thing you have there. So you are essentially
> forcing a table scan.
> I think your best bet is to create a function that does the right thing and
> still uses an index. Also I don't quite understand your need for ST_ASText
> and is your line called "poly"?
> Anyrate I would write a function something like
> CREATE OR REPLACE FUNCTION polylineintersects(polyline geometry, obs
> geometry)
> RETURNS boolean AS
> $$ SELECT $1 && $2 AND _ST_Intersects(ST_Polygon(ST_LineMerge($1)), $2) $$
> LANGUAGE 'sql' IMMUTABLE STRICT
> COST 100;
> Then replace your query with
> SELECT gid,label from shape_import_mass_tiles900913
> WHERE
> polylineintersects(poly, ST_GeomFromText('Point(-7972592.6161289
> 5242414.1716097)', 900913) ) ;
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-boun... at postgis.refractions.net
> [mailto:postgis-users-boun... at postgis.refractions.net] On Behalf Of Jedrin
> Sent: Thursday, January 14, 2010 4:16 PM
> To: postgis-us... at postgis.refractions.net
> Subject: [postgis-users] multilinestring/polygon display lookup questions
> I have a shapefile that was imported as multilinestring geo type. When I
> display it on a map it looks good as each shape is a square. When a user
> clicks on this however the postgis st_intesects() function and the like
> don't detect the click as it's not a polygon.
> If I do a conversion on the fly like this to a polygon, it seems like the
> st_astext() causes the query to run for too long:
> select gid,label from shape_import_mass_tiles900913 where
> ST_Intersects('srid=900913;Point(-7972592.6161289
> 5242414.1716097)',st_polygon(st_linemerge(ST_AsText(poly)),
> 900913)::geometry);
> If the shapefile is imported as polygons instead, then wms through
> geoserver displays the shapes over the map and obscures the map, even though
> I set transparency in openlayers/wms. I'm not sure what is the easiest way
> to get this to work to do what I want .. Currently I have two tables as a
> hack, one is polygons and the other lines, but that is really not optimal at
> all ..
> thanks
> postgis-users mailing list
> postgis-us... at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
