[postgis-users] Huge query, out of memory
Nicklas Avén nicklas.aven at jordogskog.no
Fri Jan 15 00:14:55 PST 2010
Great I have several different versions but I think the one I sent is the one best working. I have tried it on a big table and as far as I recall this version does it right. I forgot to mention:I see that I have used both CTE and window functionSo you will need PostgreSQL 8.4 to get it working /Nicklas
2010-01-15 Nicolas Gillet - MARKET-IP wrote:
Hello,
Thank you for this input.
At a first glance I did not understand it fully but Ill take time to go deeper.
Indeed a tutorial might be useful for several users as I think merging road elements is a redundant issue for GIS users.
Nicolas.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Nicklas Avén
>Envoyé : jeudi 14 janvier 2010 14:38
>À : PostGIS Users Discussion
>Objet : Re: [postgis-users] Huge query, out of memory
Hallo
I have been struggling with the same task. I don't know if I have solved it because I ran out of time a few months ago. But I attach the sql as a file with some descriptive texts. I intend to check it more properly and write some tutorial, but that will take some time before I can do.
So, no guarantees :-)
/Nicklas
> 2010-01-14 Nicolas Gillet - MARKET-IP wrote:
Hello,
I have a big shape file to process (about 300 Mo,  1.5 million records)
I have to aggregate the touching linestrings having the same attributes therefore the best way I could find (with help of this mailing list) was to aggregate all the linestrings with the same attribute and then splitting the ones that dont touch.
Here is the query :
SELECT subQ.id, subQ.feattyp, subQ.frc, subQ.shieldnum, subQ.name, null, (st_dump(merged_geom)).geom AS the_geom
FROM (
                SELECT MAX(id) AS id, feattyp, frc, MAX(shieldnum) AS shieldnum, nw.name, ST_LineMerge(ST_Collect(the_geom)) AS merged_geom
                FROM nw
                WHERE nw.frc >= 0
                GROUP BY nw.name, nw.feattyp, nw.frc
) AS subQ;
This has worked fine on smaller shapes  but on this one I get an out of memory error.
I used pgTune to change database default settings and the result is as follow :
#custom_variable_classes = ''                   # list of custom variable class names
default_statistics_target = 50 # pgtune wizard 2010-01-13
maintenance_work_mem = 120MB # pgtune wizard 2010-01-13
constraint_exclusion = on # pgtune wizard 2010-01-13
effective_cache_size = 1408MB # pgtune wizard 2010-01-13
work_mem = 12MB # pgtune wizard 2010-01-13
wal_buffers = 8MB # pgtune wizard 2010-01-13
checkpoint_segments = 16 # pgtune wizard 2010-01-13
shared_buffers = 480MB # pgtune wizard 2010-01-13
max_connections = 80 # pgtune wizard 2010-01-13
All the other parameters have their default values.
What can I do to run my script through this heavy shape files ?
Thank you
Nicolas.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100115/496036f2/attachment.html>
