[postgis-users] Installing PostGIS-1.4.1
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jan 15 03:52:54 PST 2010
Torsten Mohr wrote:
> Hello,
> thanks for your answers. It is some time ago that i used SQL, but this looks
> strange to me, PostgresQL only contains two empty tables:
> To set up PostGIS i did:
> createdb -E UTF8 -O tmohr gis
> createlang plpgsql gis
> psql -f postgis/postgis.sql
> This lead to quite many warnings. Postgres mentions that it skips several
> things. The log is below.
> So i tried:
> postgres at schleim:/local/ftp/osm> psql -d gis
> psql (8.4.1)
> Type "help" for help.
> gis=# \d
> List of relations
> Schema | Name | Type | Owner
> public | geometry_columns | table | postgres
> public | spatial_ref_sys | table | postgres
> (2 rows)
> gis=# select * from spatial_ref_sys;
> srid | auth_name | auth_srid | srtext | proj4text
> (0 rows)
> gis=# select * from geometry_columns;
> f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
> coord_dimension | srid | type
> (0 rows)
> The tables are all empty, is that ok? I fear that something went wrong here,
> as osm2pgsql dies early with the warning that several tables don't exist:
> postgres at schleim:/local/ftp/osm> osm2pgsql planet-090408.osm.bz2
> osm2pgsql SVN version 0.69-19517
> Using projection SRS 900913 (Spherical Mercator)
> Setting up table: planet_osm_point
> HINWEIS: Tabelle »planet_osm_point« existiert nicht, wird übersprungen
> HINWEIS: Tabelle »planet_osm_point_tmp« existiert nicht, wird übersprungen
> SELECT AddGeometryColumn('planet_osm_point', 'way', 900913, 'POINT', 2 );
> failed: FEHLER: AddGeometryColumns() - invalid SRID
> CONTEXT: SQL statement "SELECT AddGeometryColumn('','', $1 , $2 , $3 , $4 ,
> $5 )"
> PL/pgSQL-Funktion »addgeometrycolumn« Zeile 5 bei SQL-Anweisung
> Error occurred, cleaning up
> Isn't that a sign that something more basic went wrong?
> Thanks for any hints,
> Torsten.
You've missed just one thing after your PostGIS setup:
psql -d gis -f spatial_ref_sys.sql
Once you've done this you should then be able to see the entries in the
spatial_ref_sys table with "select * from spatial_ref_sys;".
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
