[postgis-users] RE RE : RE RE : using WKT Raster
Steve.Toutant at inspq.qc.ca
Fri Jan 15 13:00:28 PST 2010
Hi Regina,
I'm on winXP. I use postgres 8.3 and postgis 1.4.1
I copied the dll in this folder
C:\Program Files\PostgreSQL\8.3\lib
In pgAdminIII I ran rtpostgis.sql and I get this error
NOTICE: argument type raster is only a shell
ERROR: function geometry_gist_joinsel(internal, oid, internal, smallint)
does not exist
********** Error **********
does not exist
SQL state: 42883
Please Tell me if there is something I can do
thanks
Steve
"Paragon Corporation" <lr at pcorp.us>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
15/01/2010 03:32 PM
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
"'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
cc
Objet
Re: [postgis-users] RE RE : RE RE : using WKT Raster
Steve,
If you are using windows, we put up a recent version yesterday for
PostgreSQL 8.3 and 8.4 with a ReadMe.txt in it this time. Hopefully that
will answer all your questions.
http://www.postgis.org/download/windows/experimental.php
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sent: Friday, January 15, 2010 1:36 PM
To: PostGIS Users Discussion
Cc: PostGIS Users Discussion;
Subject: [postgis-users] RE RE : RE RE : using WKT Raster
I was not aware that I needed to place a DLL somewhere...Perhaps it is
obvious, but I'm not a programmer and I don't know much about dll and
software structure.
Running rtpostgis.sql and moving a dll , is that documented somewhere,
maybe I missed it.
Please provide a url if the doc to properly install WKT raster exist.
I tried copying rtpostgis.dll into C:\Program Files\PostgreSQL\8.3\lib
I don't even know if it is the right place.
I ran the sql, I got this know
NOTICE: type "raster" is not yet defined
DETAIL: Creating a shell type definition.
ERROR: function geometry_samebox(geometry, geometry) does not exist
LINE 263: AS 'select geometry_samebox($1::geometry, $2::geometry)'
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
SQL state: 42883
Hint: No function matches the given name and argument types. You might
Character: 8525
thanks
Steve
Pierre Racine <Pierre.Racine at sbf.ulaval.ca>@postgis.refractions.net
15/01/2010 01:15 PM
Veuillez répondre à
A
cc
"postgis-users-bounces at postgis.refractions.net"
<postgis-users-bounces at postgis.refractions.net>
Objet
[postgis-users] RE : RE RE : using WKT Raster
Did you first try to sort of install the WKT Raster dll at the right
location? It should go in the same "lib" folder as the PostGIS one.
Pierre
________________________________________
De : postgis-users-bounces at postgis.refractions.net
[postgis-users-bounces at postgis.refractions.net] de la part de
Steve.Toutant at inspq.qc.ca [Steve.Toutant at inspq.qc.ca]
Date d'envoi : 15 janvier 2010 12:58
À : PostGIS Users Discussion
Cc : postgis-users-bounces at postgis.refractions.net
Objet : [postgis-users] RE RE : using WKT Raster
I got this error when running the script
ERROR: could not access file "$libdir/rtpostgis": No such file or
directory
directory
SQL state: 58P01
15/01/2010 04:14 AM
Veuillez répondre à
A
cc
Objet
[postgis-users] RE : using WKT Raster
>How do I get the functions for postgis and how do I enable WKT Raster
extension?
Steve,
WKT Raster SQL functions must first be loaded in the database. You must
execute the rtpostgis.sql file located in the share/contrib folder. If you
are using pgAdmin III, just open the SQL file and execute it.
This is why it could not find the addrastercolumn function...
Hope this help,
Pierre
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100115/5b830127/attachment.html>
