[postgis-users] KML: unix vs windows
Olivier Courtin olivier.courtin at oslandia.com
Sun Jan 17 13:58:04 PST 2010
On Jan 17, 2010, at 3:14 PM, Laurens Jansen wrote:
Hi Laurens,
> when i use the asKML functions on a Postgis-UNIX machine I get the a
> fine and correct KML layer in return. Doing the same on a
> Postgis-Windows machine, the KML layer is incorrect; the coordinates
> on the windows differ from those in the Unix machine
Thanks for this report, could you send:
- As_EKWKT result (from the same points)
- SELECT postgis_full_version()     result
- if your Unix platform is 32 or 64 bits
Tks,
Olivier
