[postgis-users] KML: unix vs windows
Laurens Jansen laurens at pz.nl
Mon Jan 18 01:09:23 PST 2010
Hi Oliver
again thx for your quick response;
ad 2. The ST_AsGeoJson results set differ also:
SELECT ST_AsGeoJson(the_geom) FROM table WHERE gid=1
Unix:
"{"type":"MultiPolygon","coordinates":[[[
[121197.452000000019325,483388.473999999987427,0.000000000000000],
[121194.232643363691750,483391.530431554128882,0.000000000000000],
Windows:
[121197.45200000002,483388.47399999999,0],
[121194.23264336369,483391.53043155413,0]
ad 3 the result sets for tthe transform functions
SELECT ST_AsEWKT(ST_Transform(the_geom, 4326)) FROM table WHERE gid=1
Unix:
"SRID=4326;MULTIPOLYGON(((
4.89123288936406 52.3373804303248 0 0,
4.89118534786195 52.3374077015756 0 0,
Windows:
4.89159420399379 52.3383892154259 0 0,
4.89154665531731 52.3384164897811 0 0,
Iam also building a PostgreSQL with PostGIS 1.3 on a Windows machine,
and wil check resultset against that configuration.
regards Laurens
2010/1/18 Olivier Courtin <olivier.courtin at oslandia.com>:
> On Jan 17, 2010, at 11:21 PM, Laurens Jansen wrote:
> Hi Laurens,
> Some thoughts with theses informations:
> - We always met decimal differences upon platforms, but in this case,
> differences
>   are meaningfull and lead to wrong datas
> - PostGIS 1.4 change decimal precision handling in ST_AsKML  and ST_AsGML,
>  so it could maybe explain this issue.
>  Could you send the result (Windows and Unix) from ST_AsGeoJson export
>  (this one not been changed in 1.4 branch)
> - ST_AsKML use also ST_Transform before doing is job if data are not in
> EPSG:4326,
>  Thanks to send also result for:  SELECT ST_AsEWKT(ST_Transform(the_geom,
> 4326)) ...
> Olivier
> postgis-users mailing list
