[postgis-users] ST_transform in PostGis 1.4.0 gives error
Mike Toews
mwtoews at sfu.ca
Mon Jan 18 08:40:20 PST 2010
On 2010-01-17 23:32, Ahlmark Johan wrote:
> Hi,
> We recently updated PostGis to version 1.4.0 and after that we have a
> problem when transforming projections. The problem I am facing is that
> I want the ST-transform to return null if a projection is unable to be
> transform and not and error.
One quick workaround is to define a wrapper function or directly use
PL/pgSQL (if you need this in a function).
CREATE OR REPLACE FUNCTION st_transform_null(geometry, integer)
RETURNS geometry AS
$BODY$BEGIN
RETURN st_transform($1, $2);
EXCEPTION WHEN internal_error THEN
RETURN NULL;
END;$BODY$
LANGUAGE 'plpgsql' IMMUTABLE STRICT
COST 100;
-- Then try
select st_transform_null(PointFromText('POINT(-117.157
32.7153)',4326),3021);
See the section "Trapping Errors" in
http://www.postgresql.org/docs/current/static/plpgsql-control-structures.html
for details.
-Mike
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100118/cd9a58a0/attachment.html>
