[postgis-users] importing Raster with wkt raster
Steve.Toutant at inspq.qc.ca
Mon Jan 18 13:32:42 PST 2010
I tried importing a tif using wktraster. I used this as an example
http://mateusz.loskot.net/2009/03/30/crunching-wkt-rasters/
1-
I don't understand the use of -m parameters in the example. this option
doesn't exist in gdal2wktraster.py -h
2-
I need more information on how to use properly the -k option. Blocksize is
it the Size of the image or should I enter the pixel size
Here is the syntax I used and below the gdalinfo of my .TIF
Can you please tell if I'm importing the raster properly?
gdal2wktraster.py -r estMtl.tif -t estMtl_tif_32198 -s 32198 -o wkt.sql -k
30x30
Here is the gdalinfo of the .tif
Driver: GTiff/GeoTIFF
Files: EstMtl.tif
Size is 7771, 7410
Coordinate System is:
PROJCS["NAD_1983_Lambert_Conformal_Conic",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",46],
PARAMETER["standard_parallel_2",60],
PARAMETER["latitude_of_origin",44],
PARAMETER["central_meridian",-68.5],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-464859.388848508130000,348513.395163321870000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -464859.389, 348513.395) ( 74d37'31.17"W, 46d57'11.19"N)
Lower Left ( -464859.389, 126213.395) ( 74d23'5.99"W, 44d57'37.51"N)
Upper Right ( -231729.389, 348513.395) ( 71d33'32.58"W, 47d 5'16.37"N)
Lower Right ( -231729.389, 126213.395) ( 71d26'19.00"W, 45d 5'21.92"N)
Center ( -348294.389, 237363.395) ( 73d 0'7.85"W, 46d 1'58.13"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
NoData Value=-3.4028234663852886e+038
thanks
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100118/d5fd5c7f/attachment.html>
