[postgis-users] Questions about using SRID not -1 (SOLVED !!!)
Oscar Zamudio
cmntlk at gmail.com
Thu Jan 21 16:29:23 PST 2010
Hi Christian,
Thanks to your guide finally I could do what I wanted to.
1- The query
SELECT * FROM geometry_columns;
Returned no data showing my the_geom column was not registered in
geometry_columns as you suspected.
2- I created a new geometry column:
SELECT AddGeometryColumn( 'mypoints', 'the_geom_4326', 4326, 'POINT', 2);
that was Ok as I checked that it was registered in geometry_columns table
3-Load the data from the_geom column to the new one the_geom_4326
UPDATE mypoints SET the_geom_4326 = ST_SetSRID(the_geom,4326);
4-Check all the data entered in the_geom_4326 are with the right SRID:
select st_srid(the_geom) from mypoints;
which shown that everything is Ok.
5-Check that the points in the new column have the right data:
Select st_xmin(the_geom), st_ymin(the_geom) from mypoints
6-Drop the_geom column and rename the_geom_4326 to the_geom
6-Calculate distances in meters. An example
SELECT ST_Distance(ST_Transform(the_geom,22171),
ST_Transform(ST_GeomFromText('POINT(-58.0 0.0)', 4326),22171)) from mypoints
which returns the right results.
Thanks again Christian and everybody in the mail list for helping people to
learn PostGIS.
Regards,
Mario
On Thu, Jan 21, 2010 at 6:49 PM, Chris Hermansen <
> if your table is in there, you will see a line that contains its name in
> f_table_name and its geometry column in f_geometry_column. You don't need
> to guess. Check its SRID there.
> You have some spatial queries that work ok with an SRID of -1. Things like
> st_transform() don't work with an unknown SRID (which is what a -1 means).
> AFAIK some of these operations need a row in geometry_columns.
> Oscar Zamudio wrote:
>> How can I test if it is not registered?. Nevertheless all the other
>> spatial queries are working well (ST_distanc for example) so I guess it is
>> registered. On the contrary ther will be no access to this kind of
>> operations.
>> On Thu, Jan 21, 2010 at 5:24 PM, Chris Hermansen <
>> chris.hermansen at timberline.ca <mailto:chris.hermansen at timberline.ca>>
>> wrote:
>> Maybe your column is not registered in geometry_columns?
>> Chris Hermansen chris.hermansen at timberline.ca
>> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.840.4625
>> Timberline Natural Resource Group · www.timberline.ca
>> <http://www.timberline.ca>
>> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
>> -----Original Message-----
>> From: Oscar Zamudio <cmntlk at gmail.com <mailto:cmntlk at gmail.com>>
>> Date: Thu, 21 Jan 2010 17:14:59
>> To: PostGIS Users Discussion<postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>>
>> Subject: Re: [postgis-users] Questions about using SRID not -1
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen · chris.hermansen at timberline.ca · skype:clhermansen
> Timberline Natural Resource Group Ltd · http://www.timberline.ca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100121/4acce017/attachment.html>
