[postgis-users] ST_distance in meters
ibrahim saricicek
ibrahimsaricicek at gmail.com
Fri Jan 22 03:40:39 PST 2010
Hi;
For 4326 projection distance unit is in degrees.
Google maps use 900913 projection code, and units for this projection.
To get the same distance calculation; firstly add 900913 projection to
spatial_ref_sys table.
Then use this query
select
st_distance(st_transform(tableA.colB,900913),st_transform(tableA.colC,900913))
Regards..
IBO..
On Fri, Jan 22, 2010 at 1:17 PM, lomarod <lomarodpostgis at hotmail.com> wrote:
> Hi,
> I have a table "tableA" with the column "colB" and "colC" type geometry.
> tableA.colB = geometryfromtext('POINT('-19.922488 -43.9367')',4326)
> tableA.colC = geometryfromtext('POINT('-19.926357 -43.934223')',4326)
> Using google earth or google maps, a have the distance between this two
> points in 500 meters.
> When I execute the query
> select st_distance(tableA.colB, tableA.colC) from tableA my result is
> 0,004593984...
> How can I have the same result as google maps ?
> What am I doing wrong ?
> http://old.nabble.com/ST_distance-in-meters-tp27271750p27271750.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100122/819e732a/attachment.html>
