[postgis-users] RE Importing shapefiles to PostGIS
P Kishor
punk.kish at gmail.com
Sat Jan 23 18:47:32 PST 2010
On Sat, Jan 23, 2010 at 8:42 PM, Shreerang Patwardhan
<patwardhan.shreerang at gmail.com> wrote:
> Hello all,
> I have followed steps to import TIGER shapefile to PostGIS . I got
> the following output and errors.
> shreerang at ubuntu:~/Shapefiles/
> 06001_Alameda_County/tl_2008_06001_arealm$ shp2pgsql -s 4326 -I -S
> tl_2008_06001_arealm.shp public.test_db > tl_2008_06001_arealm.sql
> Shapefile type: Polygon
> Postgis type: POLYGON[2]
> shreerang at ubuntu:~/Shapefiles/06001_Alameda_County/tl_2008_06001_arealm$
> psql -d test_db -U postgres -f import.sql
> psql: FATAL: Ident authentication failed for user "postgres"
Have you been able to log into Postgres at all? Try logging in as user
"postgres" and whatever password you set when you installed it. You
can try and force a password prompt with -W. Type psql --help on your
command prompt for all the options.
su as postgres and then try importing.
Puneet Kishor
