[postgis-users] Get point certain degree of another point
tommy408
tommytomorow at msn.com
Sun Jan 24 20:11:46 PST 2010
Thank you Marc and Mike
Mike Toews wrote:
> On 2010-01-22 19:05, tommy408 wrote:
>> How can I get a point at a certain distance and degree from another
>> point.
>> For example 10 meter distance to another point at 45 degrees.
> You could also use some simple trigonometry with ST_Translate().
> For example, consider 'geom' at (100 100), and a point 12 units away 30
> degrees from the x-axis (math style with CCW direction .. or a
> geographic bearing of 60 degrees CW from North).
> SELECT AsEWKT(ST_Translate(geom, cos(rad)*dist, sin(rad)*dist))
> FROM (select ST_MakePoint(100, 100) as geom, 12 as dist, 30*2*pi()/360
> as rad) AS foo;
> POINT(110.392304845413 106)
> Or your example from (0 0) using a math-style angle:
> FROM (select ST_MakePoint(0, 0) as geom, 10 as dist, 45*2*pi()/360 as
> rad) AS foo;
> POINT(7.07106781186548 7.07106781186547)
> This could easily be turned into a PL/pgSQL function if you require it
> frequently. Also, be aware of the geographic versus mathematics
> definition of angles, since they have opposite rotations and start 90
> degrees from each other.
> -Mike
> postgis-users mailing list
View this message in context: http://old.nabble.com/Get-point-certain-degree-of-another-point-tp27282672p27301970.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
