[postgis-users] update an st_intersects
ibrahim saricicek
ibrahimsaricicek at gmail.com
Tue Jan 26 04:26:59 PST 2010
Hi all,
Thanks, understand.
Ok, is there another way to update poi's province.ogc_fid with the bounding
province's ogc_fid ???
Namely i want to learn the province of POI's...
Regards..
On Tue, Jan 26, 2010 at 2:20 PM, Rafael Soto <rafael.soto at gmail.com> wrote:
> Hello my friend..
> Your query is not wrong but your record true..
> When you call a subselect to complete your UPDATE operation, this subselect
> can be only one row in result return.
> To correct this, you must be define one filter to decide what the result
> you want to UPDATE.
> To see the mistake, execute a subselect {{{ select* province.ogc_fid from
> province,poi where intersects(poi.the_geom, province.the_geom)=True group by
> province.ogc_fid* }} and check the number of rows in the resultset.
> On Tue, Jan 26, 2010 at 9:57 AM, ibrahim saricicek <
> ibrahimsaricicek at gmail.com> wrote:
>> Hi all,
>> I have two tables; provinces an points of interests. I wanna update
>> province_id column with st_intersects function..
>> My sql;
>> update poi set province_id=(
>> select province.ogc_fid from province,poi where intersects(poi.the_geom,
>> province.the_geom)=True group by province.ogc_fid
>> The message is
>> ERROR: more than one row returned by a subquery used as an expression
>> What should I change?
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Rafael Soto
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100126/2c317848/attachment.html>
