[postgis-users] update an st_intersects
ibrahim saricicek ibrahimsaricicek at gmail.com
Tue Jan 26 06:10:52 PST 2010
Hi all,
The same error
ERROR: more than one row returned by a subquery used as an expression
any comments?
On Tue, Jan 26, 2010 at 2:30 PM, Rafael Soto <rafael.soto at gmail.com> wrote:
> Try it
> update poi set province_id=(
> select province.ogc_fid from province where intersects(poi.the_geom,
> province.the_geom)=True group by province.ogc_fid
> On Tue, Jan 26, 2010 at 10:26 AM, ibrahim saricicek <
> ibrahimsaricicek at gmail.com> wrote:
>> Hi all,
>> Thanks, understand.
>> Ok, is there another way to update poi's province.ogc_fid with the
>> bounding province's ogc_fid ???
>> Namely i want to learn the province of POI's...
>> Regards..
>> On Tue, Jan 26, 2010 at 2:20 PM, Rafael Soto <rafael.soto at gmail.com>wrote:
>>> Hello my friend..
>>> Your query is not wrong but your record true..
>>> When you call a subselect to complete your UPDATE operation, this
>>> subselect can be only one row in result return.
>>> To correct this, you must be define one filter to decide what the result
>>> you want to UPDATE.
>>> To see the mistake, execute a subselect {{{ select*  province.ogc_fid
>>> from province,poi where intersects(poi.the_geom, province.the_geom)=True
>>> group by province.ogc_fid* }} and check the number of rows in the
>>> resultset.
>>> On Tue, Jan 26, 2010 at 9:57 AM, ibrahim saricicek <
>>>> Hi all,
>>>> I have two tables; provinces an points of interests. I wanna update
>>>> province_id column with st_intersects function..
>>>> My sql;
>>>> select province.ogc_fid from province,poi where intersects(poi.the_geom,
>>>> The message is
>>>> What should I change?
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Rafael Soto
> Rafael Soto
> Sent from Brasilia, DF, Brazil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100126/25b7acbc/attachment.html>
