[postgis-users] RE Importing shapefiles to PostGIS
Ben Madin lists at remoteinformation.com.au
Thu Jan 28 21:30:04 PST 2010
You can also read in SQL commands into psql using the \i command, for instance :
testdb=# \i ~/Shapefiles/06001_Alameda_County/tl_2008_06001_arealm/tl_2008_06001_arealm.sql
should read it in...
At least this should get you around the authentication issues...
cheers
Ben
On 29/01/2010, at 12:06 , Shreerang Patwardhan wrote:
> Hi all,
>     I am still stuck at this "Ident authentification error"...<323.png> The sequence of commands that I used and their outputs are as below:
> shreerang at ubuntu:~/Shapefiles/06001_Alameda_County/tl_2008_06001_arealm$ shp2pgsql -s 4326 -I -S tl_2008_06001_arealm.shp public.testdb > tl_2008_06001_arealm.sql
> Shapefile type: Polygon
> Postgis type: POLYGON[2]
> shreerang at ubuntu:~/Shapefiles/06001_Alameda_County/tl_2008_06001_arealm$ psql -d testdb -h localhost -p 5432 -U postgres
> Welcome to psql 8.3.9 (server 8.4.2), the PostgreSQL interactive terminal.
> testdb=# psql -d testdb -U postgres -f tl_2008_06001_arealm.sql
> What should be the output of this command at the terminal? On entering this command the terminal gives a new promt. Is this the desired output?
> When I use the command  testdb-# \d  I get the output as:
>               List of relations
>  Schema |       Name       | Type  |  Owner
>  public | geometry_columns | table | postgres
>  public | spatial_ref_sys  | table | postgres
> (2 rows)
> Please help guys!!!
> postgis-users mailing list
