[postgis-users] Split a polygon to N linestrings
Kevin Neufeld kneufeld at refractions.net
Fri Jan 29 08:44:15 PST 2010
CREATE TEMP TABLE mypolygontable AS
SELECT
   'MULTIPOLYGON(((0 0, 0 4, 4 4, 4 0, 0 0),
                  (1 1, 1 2, 2 2, 2 1, 1 1)),
                 ((5 5, 5 6, 6 6, 6 5, 5 5))
                )'::geometry geom;
-- make line segments from every startpoint and endpoint
SELECT ST_AsText( ST_MakeLine(sp,ep) )
FROM
   -- extract the endpoints for every 2-point line segment for each linestring
   (SELECT
      ST_PointN(geom, generate_series(1, ST_NPoints(geom)-1)) as sp,
      ST_PointN(geom, generate_series(2, ST_NPoints(geom)  )) as ep
    FROM
       -- extract the individual linestrings
      (SELECT (ST_Dump(ST_Boundary(geom))).geom
       FROM mypolygontable
       ) AS linestrings
    ) AS segments;
       st_astext
  LINESTRING(0 0,0 4)
  LINESTRING(0 4,4 4)
  LINESTRING(4 4,4 0)
  LINESTRING(4 0,0 0)
  LINESTRING(1 1,1 2)
  LINESTRING(1 2,2 2)
  LINESTRING(2 2,2 1)
  LINESTRING(2 1,1 1)
  LINESTRING(5 5,5 6)
  LINESTRING(5 6,6 6)
  LINESTRING(6 6,6 5)
  LINESTRING(6 5,5 5)
(12 rows)
Cheers,
Kevin
On 1/29/2010 5:16 AM, Nicolas Gillet - MARKET-IP wrote:
> Hello,
> I am looking for some tips to split a polygon to its simplest linestrings.
> An example worth better than words :
> POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))
> Would become :
> MULTINLINESTRING((0 0, 0 1), (0 1, 1 1), (1 1, 1 0), (1 0, 0 0))
> Every single linestring has to have two and only two points.
> Is there a way to do this with the existing postgis functions ?
> I found several ways to turn a polygon to a (multi)linestring but not to
> split it then into shortest linestrings.
> Thanks for any input.
> Nicolas
> Gillet
> postgis-users mailing list
