[postgis-users] speed difference between using operators and st_* functions
James Chamberlain
james.chamberlain at gmail.com
Wed Jun 2 19:14:25 PDT 2010
I have a large dataset with many polygons, points, and
geometrycollections and I have been testing different ways to query with
very different results. I am querying for geometries within a bounding
box or a radius from a point. I seem to get the best performance if I
create a polygon to represent the bounding box or circle and then use
operators such as && or @. If I instead use functions like st_intersects
or st_contains the same operation takes much longer. Is that the
expected behavior? Another benefit of using the operators is that they
work with geometrycollections where many of the functions do not. Is
there any reason to prefer the functions over operators for basic
intersection and contains queries?
Thanks,
James
