[postgis-users] Using grids transformation method with PostGis
Francis Markham
fmarkham at gmail.com
Tue Jun 8 09:47:18 PDT 2010
I would also be interested in the answer to this question. Currently I
export PostGIS data to shapefiles and use ogr2ogr to transform, if a grid
shift is required. Perhaps the solution to this problem could be documented
on the ST_Transform() page in the PostGIS manual?
Cheers,
Francis
2010/6/9 Luís de Sousa <luis.a.de.sousa at gmail.com>
> Hello everyone,
> I'm trying to convert a series of spatial features from one SRS to
> another within PostGIS. Both are local systems for continental
> Portugal, for which a set of grid definition files have been made
> available by the University of Oporto. I downloaded these grid files
> and copied them into /usr/share/proj and /usr/local/share/proj. That
> was enough to get proj to start using them.
> The problem is, when invoking the same transformation from PostGis I'm
> getting errors in the range of tenths, sometimes hundreds, of metres.
> It seems like PostGis is failing to use the grid files. In attachment
> goes a log demonstrating the same transformation having different
> results with proj and PostGis.
> What am I missing? Is there any extra configuration needed for PostGis
> to use the grid files?
> Thank you,
> Luís
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100609/1d1072de/attachment.html>
