[postgis-users] Shapefile GUI loader
Tahir Tamba
tahir.tamba at gmail.com
Thu Jun 10 13:56:35 PDT 2010
Hi Leo and Regina,
Tkank you for your quick answer and pointing me the reasons why I could'nt
see the PostGIS GUI Shape Loader. As you mentionned it to me, it seems to be
the second reason, because I installed the new PostgreSQL and PostGIS
version and have an older version up and running on my WinXP. I'll test the
new setup and hope that will fix the issue.
Cheers
2010/6/9 Paragon Corporation <lr at pcorp.us>
> There are usually 2 reasons why it doesn't show
> 1) You are using PgAdmin III that is not under PostgreSQL. The plugins.ini
> that gets installed gets installed in the PgAdmin III that comes with
> PostgreSQL. Easy fix is to copy the plugins.ini from PostgreSQL /pgAdminIII
> to the one you are using
> 2) Your bin folder of PgAdminIII is pointing at an older install.
> <http://www.postgresonline.com/journal/index.php?/archives/145-PgAdmin-III-Plug-in-Registration-PostGIS-Shapefile-and-DBF-Loader.html>
> Details here
> http://www.postgis.us/screencast_postgis_gui_shapeloader
> and
> here
> Leo and Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Tahir Tamba
> *Sent:* Wednesday, June 09, 2010 4:04 PM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Shapefile GUI loader
> Hi,
> I've installed PostgreSQL 8.4.4 and PostGIS 1.5.1 on Windows XP, using
> Windows installer version and installed PostGIS on top of PostgreSQL with
> stackbuilder by accepting shape loader install during the install process.
> Unfortunatly when I started pgAdmin III the Shapefile GUI loader is missing.
> Can anyone tell me what is going on ?
> Thank
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100610/8b7149c9/attachment.html>
