[postgis-users] Using grids transformation method with PostGis
Luís de Sousa
luis.a.de.sousa at gmail.com
Fri Jun 11 01:47:24 PDT 2010
On Wed, Jun 9, 2010 at 7:53 PM, Mike Toews <mwtoews at gmail.com> wrote:
> The file name "ptLX_e89.gsb" is case sensitive on *nix systems. Is
> your file mixed case, all upper or all lower case?
Hi Mike, thank your for your reply.
The filename is exactly the same on the file system:
$ ls -la /usr/share/proj/*.gsb
-rw-r--r-- 1 root root 277424 2009-12-01 13:31 /usr/share/proj/ntf_r93.gsb
-rw-r--r-- 1 root root 318464 2009-12-01 13:31
/usr/share/proj/nzgd2kgrid0005.gsb
-rw-rw-rw- 1 root root 40368 2008-11-23 19:50 /usr/share/proj/pt73_e89.gsb
-rw-rw-rw- 1 root root 40368 2008-11-23 19:56 /usr/share/proj/ptED_e89.gsb
-rw-rw-rw- 1 root root 40368 2008-11-23 19:54 /usr/share/proj/ptLB_e89.gsb
-rw-rw-rw- 1 root root 40368 2008-11-23 19:49 /usr/share/proj/ptLX_e89.gsb
Luís
