[postgis-users] Using DBI Placeholders for GeomFromText
Stuart Gralton
sgralton at gmail.com
Fri Jun 11 21:27:28 PDT 2010
Hello Everybody,
Is it possible to use Perl DBI placeholders to insert a geometry into a
table using GeomFromText.
When I try the following;
$sth = $dbh->prepare("INSERT INTO table (gid, the_geom) VALUES (?,?)");
$sth->execute(1, GeomFromText('POINT(1 1)', 4326));
an error is produced:
ERROR: parse error - invalid geometry
HINT: You must specify a valid OGC WKT geometry type such as POINT,
LINESTRING or POLYGON
The following statement works fine:
INSERT INTO table (gid, the_geom) VALUES (1, GeomFromText('POINT(1 1)',
4326));
I am not entirely sure if this is more of a DBI question or a POSTGIS
question, but maybe someone can help?
Thanks,
Stuart
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100612/84d0fe41/attachment.html>
