[postgis-users] Using DBI Placeholders for GeomFromText
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 11 21:48:04 PDT 2010
Stuart Gralton wrote:
> Hello Everybody,
> Is it possible to use Perl DBI placeholders to insert a geometry into a
> table using GeomFromText.
> When I try the following;
> $sth = $dbh->prepare("INSERT INTO table (gid, the_geom) VALUES (?,?)");
> $sth->execute(1, GeomFromText('POINT(1 1)', 4326));
You might try something like this.
VALUES (?, GeomFromText(?, 4326))");
$sth->execute(1, 'POINT(1 1)');
I'm not sure it is valid to pass arbitrary SQL via a place holder.
GeomFromText() is a function and not a variable.
-Steve
> an error is produced:
> ERROR: parse error - invalid geometry
> HINT: You must specify a valid OGC WKT geometry type such as
> POINT, LINESTRING or POLYGON
> The following statement works fine:
> INSERT INTO table (gid, the_geom) VALUES (1, GeomFromText('POINT(1
> 1)', 4326));
> I am not entirely sure if this is more of a DBI question or a POSTGIS
> question, but maybe someone can help?
> Thanks,
> Stuart
> postgis-users mailing list
