[postgis-users] Using DBI Placeholders for GeomFromText
Stuart Gralton sgralton at gmail.com
Sat Jun 12 00:09:32 PDT 2010
Thank you Steve et al.  That worked perfectly.
I did have some trouble with the single quotes when substituting 'POINT(1
1)' with variables. However the following works, if anyone else ever needs
to know:
$sth = $dbh->prepare("INSERT INTO table (gid, the_geom)  VALUES (?,
GeomFromText(?, 4326))");
$some_geometry = "POINT(1 1)";
$sth->execute(1, $some_geometry);
The single quotes are all sorted by DBI.
Cheers,
Stuart
On Sat, Jun 12, 2010 at 1:03 PM, P Kishor <punk.kish at gmail.com> wrote:
> On Fri, Jun 11, 2010 at 11:48 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
> > Stuart Gralton wrote:
> >> Hello Everybody,
> >> Is it possible to use Perl DBI placeholders to insert a geometry into a
> >> table using GeomFromText.
> >> When I try the following;
> >>     $sth->execute(1, GeomFromText('POINT(1 1)', 4326));
> > You might try something like this.
> >                            VALUES (?, GeomFromText(?, 4326))");
> >      $sth->execute(1, 'POINT(1 1)');
> > I'm not sure it is valid to pass arbitrary SQL via a place holder.
> > GeomFromText() is a function and not a variable.
> Steve is correct. I just tested his suggested syntax, and it works.
> > -Steve
> >> an error is produced:
> >>     ERROR:  parse error - invalid geometry
> >>     HINT:  You must specify a valid OGC WKT geometry type such as POINT,
> >> LINESTRING or POLYGON
> >> The following statement works fine:
> >>     INSERT INTO table (gid, the_geom) VALUES (1, GeomFromText('POINT(1
> >> 1)', 4326));
> >> I am not entirely sure if this is more of a DBI question or a POSTGIS
> >> question, but maybe someone can help?
> >> Thanks,
> >> Stuart
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> Assertions are politics; backing up assertions with evidence is science
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100612/2d60902b/attachment.html>
