[postgis-users] Using grids transformation method with PostGis
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Jun 15 09:12:48 PDT 2010
Hello everyone,
I have tried to sort this issue in several ways, checking the correct
projection settings, trying other installations of PostGis but the
problem remains: PostGis seems unable to use the proj files for the
grid transformation method.
Is this a bug that should be reported? How can I do so?
Thank you,
Luís
