[postgis-users] Create POLYGON from Several LINESTRINGs
Avery Penniston apenniston at geo-comm.com
Tue Jun 22 12:23:37 PDT 2010
Here is a sample function to help illustrate the issue (you can perform
a simple test by calling 'Select wedgefunc(1,1,1) as test;'):
CREATE OR REPLACE FUNCTION wedgefunc(outerradius float, startangle
float, openingangle float)
  RETURNS text AS
$BODY$
  DECLARE
    startchord geometry;
    midchord geometry;
    endchord geometry;
    revstartchord geometry;
    outerarc text;
    outerarcline geometry;
    polyborder geometry;
    poly geometry;
  BEGIN
  -- Rotate a horizontal line to form chords - the 'mid' chord is to
help form the CIRCULARLINESTRING
                startchord :=
st_rotate(st_makeline(st_point(0,0),st_point(outerradius,0)),startangle)
                midchord :=
+ (.5 * openingangle));
                endchord :=
+  openingangle);
  --Make a reversal of the start chord - just in case the points need to
be in order when putting together the poly
                revstartchord := st_reverse(startchord);
  --Create an arc line by passing the endpoints of the endchord,
midchord, and startchord
                outerarc :=
'CIRCULARSTRING('||st_x(st_endpoint(endchord))||'
'||st_y(st_endpoint(endchord))||','||st_x(st_endpoint(midchord))||'
'||st_y(st_endpoint(midchord))||','||st_x(st_endpoint(startchord))||'
'||st_y(st_endpoint(startchord))||')';
                outerarcline := st_curvetoline(outerarc);
  --Create the single LINESTRING representing the border by combining
the individual LINESTRINGS
                polyborder :=
st_union(st_union(revstartchord,endchord),outerarcline);
                --polyborder :=
st_collect(st_collect(revstartchord,endchord),outerarcline);
  --Debugging
                --return st_astext(startchord);
                --return st_astext(midchord);
                --return st_astext(endchord);
                --return st_astext(revstartchord);
                --return st_astext(outerarcline);
                --return st_astext(polyborder);
  --Create the POLYGON geometry and return it
                poly := st_polygon(polyborder,-1);
                return st_astext(poly);
  END;
  $BODY$
  LANGUAGE 'plpgsql' IMMUTABLE;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100622/e70481b2/attachment.html>
