[postgis-users] Create POLYGON from Several LINESTRINGs
Avery Penniston apenniston at geo-comm.com
Tue Jun 22 13:00:03 PDT 2010
Thanks for the reply.
I tried to use the st_buildarea with st_collect as you suggested by
modifying my wedgefunc function that I posted earlier.  However, now I
don't get anything out of the function.  I believe the collect is
returning a MULTILINESTRING with the three elements to my wedge in it,
but for some reason the st_buildarea function is returning nothing.  Any
ideas?
Here is my modified wedgefunc function:
CREATE OR REPLACE FUNCTION wedgefunc(outerradius float, startangle
float, openingangle float)
  RETURNS text AS
$BODY$
  DECLARE
    startchord geometry;
    midchord geometry;
    endchord geometry;
    revstartchord geometry;
    outerarc text;
    outerarcline geometry;
    polyborder geometry;
    poly geometry;
  BEGIN
  -- Rotate a horizontal line to form chords - the 'mid' chord is to
help form the CIRCULARLINESTRING
                startchord :=
st_rotate(st_makeline(st_point(0,0),st_point(outerradius,0)),startangle)
                midchord :=
+ (.5 * openingangle));
                endchord :=
+  openingangle);
  --Make a reversal of the start chord - not sure if this is needed,
just incase the points need to be in order when putting together the
poly
                revstartchord := st_reverse(startchord);
  --Create an arc line by passing the endpoints of the endchord,
midchord, and startchord
                outerarc :=
'CIRCULARSTRING('||st_x(st_endpoint(endchord))||'
'||st_y(st_endpoint(endchord))||','||st_x(st_endpoint(midchord))||'
'||st_y(st_endpoint(midchord))||','||st_x(st_endpoint(startchord))||'
'||st_y(st_endpoint(startchord))||')';
                outerarcline := st_curvetoline(outerarc);
  --TRYING ST_BUILDAREA WITH ST_COLLECT AFTER UNIONING THE 3 LINESTRINGS
                poly := st_buildarea(st_collect(geom))
                FROM (select revstartchord as geom
                                union select endchord as geom
                                union select outerarcline as geom
                ) as u;
                return st_astext(poly);
  END;
  $BODY$
  LANGUAGE 'plpgsql' IMMUTABLE;
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Randall, Eric
Sent: Tuesday, June 22, 2010 2:26 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Create POLYGON from Several LINESTRINGs
I think perhaps st_buildarea and st_collect might be what you want.
Below is what I used to create a hexagon out of points->lines which was
then translated (using generate_series) across X and Y to create a
hexagonal grid for the County.   There's probably a simpler way to make
a hexagon but it illustrates the st_buildarea.  Maybe that helps.
-Eric
--let's make a hexagon with 1000 foot sides and position it with it's
--center at 1210000, 610000 (the lower left of the pamap tile extent for
Erie County)
--and create a table
drop table if exists hex1000;
create table hex1000 as
select translate(st_buildarea(st_collect(geom)),1210000, 610000) as geom
from
(select makeline(st_endpoint(makeline(makepoint(0, 0),makepoint(0, -
1000))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(300)))) as geom
union select makeline(st_endpoint(rotate(makeline(makepoint(0,
0),makepoint(0, -1000)),
radians(300))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(240))))  as geom
radians(240))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(180))))  as geom
radians(180))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(120))))  as geom
radians(120))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(60))))  as geom
radians(60))),st_endpoint(rotate(makeline(makepoint(0, 0),makepoint(0,
-1000)), radians(0))))  as geom
) as t1;
-----Original Message-----
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Avery
Penniston
Sent: Tuesday, June 22, 2010 2:38 PM
To: postgis-users at postgis.refractions.net
	I'm trying to create 'pie wedge' shaped polygons by building
them in a Postgres function.  I am able to create the 2 straight chords
and the arc as separate LINESTRINGs, and I have verified that each
LINESTRING shares its endpoints with the other two LINESTRINGs.
However, I am having trouble putting the individual parts together to
form a POLYGON.
	I tried to ST_UNION the 3 LINESTRINGs together, and the result
is a MULTILINESTRING.  I then call ST_LINEMERGE to convert the
MULTILINESTRING to a single LINESTRING so I can pass it to the
ST_POLYGON function, but the result of the ST_LINEMERGE is a
MULTILINESTRING.
	I tried using ST_COLLECT instead of ST_UNION, but then I got a
GEOMETRYCOLLECTION containing a MULTILINESTRING and a LINESTRING.
	Does anybody have some advice for creating a POLYGON from 3 or
more separate LINESTRINGs?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100622/dddd59f2/attachment.html>
