[postgis-users] Error in shp2pgsql
Paul Ramsey pramsey at opengeo.org
Tue Jun 22 13:29:51 PDT 2010
João Paulo,
If you could provide the shapefile in question (or, even better, a
reduced version with just the one polygon that causes trouble) that
would make it easier for us to fix things up!
Thanks
P
2010/6/22 João Paulo Hespanha <jphespanha at gmx.com>:
> Dear Sirs:
> While importing a shapefile produced from an ESRI personal geodatabase,
> consisting of a total of 609 polygons, I got the error which I report in
> the below transcript (a bit long... as usual).
> Later, I found out that the program was crashing due to a incorrect
> polygon, having shape length and area equal to zero. Now I know that
> ArcGIS accepts such misformed polygons in the geodatabase...
> I have also used SPIT (a QGIS plugin), which did not give me problems
> respecting the import and simply ignored the erroneous polygon, although
> it did not informed me of the fact.
> FYI, I am using release 1.5 of shp2pgsql and:
> "POSTGIS="1.3.5" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
> 2009" USE_STATS"; "PostgreSQL 8.3.8 on i486-pc-linux-gnu, compiled by
> GCC gcc-4.4.real (Ubuntu 4.4.1-3ubuntu3) 4.4.1"
> Transcript from my session:
> jphespanha at JPHUbuntu:~/Documentos/Tese/ImplementationTest_2010/ArcGISshapes$ shp2pgsql -c -s 9102160 Predio_Polygons public.predio_polygons > predio_polys.sql
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> *** glibc detected *** shp2pgsql: corrupted double-linked list:
> 0x084a9c78 ***
> ======= Backtrace: =========
> /lib/tls/i686/cmov/libc.so.6[0xe3f0d1]
> /lib/tls/i686/cmov/libc.so.6[0xe40b69]
> /lib/tls/i686/cmov/libc.so.6(cfree+0x6d)[0xe438ad]
> shp2pgsql[0x8053345]
> shp2pgsql[0x8053d76]
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6)[0xdeab56]
> shp2pgsql[0x8049ed1]
> ======= Memory map: ========
> 0068d000-0068e000 r-xp 00000000 00:00 0          [vdso]
> 00931000-00955000 r-xp 00000000 08:01
> 1967425    /lib/tls/i686/cmov/libm-2.10.1.so
> 00955000-00956000 r--p 00023000 08:01
> 00956000-00957000 rw-p 00024000 08:01
> 009e3000-009e5000 r-xp 00000000 08:01
> 534769     /usr/lib/gconv/CP1252.so
> 009e5000-009e6000 r--p 00001000 08:01
> 009e6000-009e7000 rw-p 00002000 08:01
> 00d6b000-00d87000 r-xp 00000000 08:01 2352       /lib/libgcc_s.so.1
> 00d87000-00d88000 r--p 0001b000 08:01 2352       /lib/libgcc_s.so.1
> 00d88000-00d89000 rw-p 0001c000 08:01 2352       /lib/libgcc_s.so.1
> 00dd4000-00f12000 r-xp 00000000 08:01
> 1967417    /lib/tls/i686/cmov/libc-2.10.1.so
> 00f12000-00f13000 ---p 0013e000 08:01
> 00f13000-00f15000 r--p 0013e000 08:01
> 00f15000-00f16000 rw-p 00140000 08:01
> 00f16000-00f19000 rw-p 00000000 00:00 0
> 00f53000-00f6e000 r-xp 00000000 08:01 146        /lib/ld-2.10.1.so
> 00f6e000-00f6f000 r--p 0001a000 08:01 146        /lib/ld-2.10.1.so
> 00f6f000-00f70000 rw-p 0001b000 08:01 146        /lib/ld-2.10.1.so
> 08048000-0807b000 r-xp 00000000 08:01 4134       /usr/bin/shp2pgsql
> 0807b000-0807c000 r--p 00032000 08:01 4134       /usr/bin/shp2pgsql
> 0807c000-0807d000 rw-p 00033000 08:01 4134       /usr/bin/shp2pgsql
> 084a6000-084c7000 rw-p 00000000 00:00 0          [heap]
> b7600000-b7621000 rw-p 00000000 00:00 0
> b7621000-b7700000 ---p 00000000 00:00 0
> b77f4000-b77f6000 rw-p 00000000 00:00 0
> b7800000-b7801000 rw-p 00000000 00:00 0
> b7801000-b7808000 r--s 00000000 08:01
> 534863     /usr/lib/gconv/gconv-modules.cache
> b7808000-b780d000 rw-p 00000000 00:00 0
> bf7f9000-bf80e000 rw-p 00000000 00:00 0          [stack]
> Abortado
> I really have to do an update on this old versions of postgresql
> +postgis!!! :-)
> Perhaps the question is already solved, but if not, this could be
> helpful.
> postgis-users mailing list
