[postgis-users] Error in shp2pgsql
João Paulo Hespanha jphespanha at gmx.com
Wed Jun 23 13:20:30 PDT 2010
Here is the "offending" shapefile, that is, the polygon that is giving
the error, which has parcel number (npredio=148). The attribute data can
be read by (for example) uDIG.
I received a solution from the portugal osgeo list, which consists in
using the "-N skip" option in the command line, and this works. The
option of inserting a Null geometry does not work.
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100623/bed927b2/attachment.zip>
