[postgis-users] Polygon to line
Edward Mac Gillavry emacgillavry at hotmail.com
Thu Jun 24 13:24:14 PDT 2010
Hi Ricardo,
Having been through the mailing list's archives myself over the last few weeks, i came up with the following recipe:
	First you dump all multipolygons into polygons:
SELECT
    (ST_Dump(the_geom)).geom AS the_geom
INTO  polygon_table
FROM multipolygon_table
and create an index on that one
CREATE INDEX geo_idx_polygon_temp ON polygon_table_temp USING GIST (the_geom);
VACUUM ANALYZE polygon_table_temp;
then you create a new table that contains the borders using ST_Intersection:
CREATE TABLE borders AS
SELECT
    ST_Intersection(t1.the_geom,t2.the_geom) AS the_geom
FROM
    polygon_table_temp AS t1,
    polygon_table_temp AS t2
WHERE
    t1.the_geom && t2.the_geom;
These borders are duplicated, as the intersection is computed twice (A intersects B and B intersects A). Also contains records of geometry other than multilinestring
DELETE FROM borders WHERE GeometryType(the_geom) <> 'MULTILINESTRING'::text;
SELECT Populate_Geometry_Columns('borders'::regclass);
ALTER TABLE borders ADD COLUMN gid SERIAL;
ALTER TABLE borders ADD PRIMARY KEY (gid);
CREATE INDEX geo_idx_borders ON borders USING GIST (the_geom);
VACUUM ANALYZE borders;
 so remove duplicates:
borders.gid <
(SELECT  MAX(b.gid )
    FROM borders b
    WHERE b.the_geom && borders.the_geom
        AND ST_Equals(borders.the_geom, b.the_geom));
REINDEX TABLE borders;
That should do it. Thanks to previous postings to this mailing list!
regards,
Edward
Date: Thu, 24 Jun 2010 16:53:54 -0300
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Polygon to line
Hi all, is the first time I use the list. I have a polygon that represent a country, if i want extract only the sides that touch with other polygon. How i have to do? The result should be a MultiLineString or a LineString representing the limits of the country but without the coast line if it has one. I tried with ST_Touches but i can't get it work.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100624/a43063ef/attachment.html>
