[postgis-users] Wondering why I can't use the geometry type in a CREATE statement.
Greg Militello
junk at thinkof.net
Sun Jun 27 19:03:49 PDT 2010
I am just wondering why PostGIS does not create nee datatypes in a way that allows a CREATE statement to make them. There is an example in the doc that looks like this:
CREATE TABLE parks (
park_id INTEGER,
park_name VARCHAR,
park_date DATE,
park_type VARCHAR
SELECT AddGeometryColumn('parks', 'park_geom', 128, 'MULTIPOLYGON', 2 );
Why isn't this possible?
park_id INTEGER,
park_name VARCHAR,
park_date DATE,
park_type VARCHAR,
parks GEOMETRY(128, 'MULTIPOLYGON', 2)
Or something similar. Having to create the column as an after effect makes it difficult to use PostGIS with database abstraction layers. Most of the good DBALs allow the use of custom column types, however they do not usually support post create statement column generation (maybe with an exception here or there with ALTER TABLE commands).
Specifically I am looking into extending doctrine (a PHP DBAL/ORM) to utilize spacial DBs.
