[postgis-users] Insertings quite big MULTILINESTRING fails
Charles Galpin
cgalpin at lhsw.com
Tue Mar 2 06:40:37 PST 2010
This came up the other day. It's a display limitation of spql or pgadmin. Try this
select st_length(the_geom), st_asText(st_startpoint(the_geom)), st_asText(st_endpoint(the_geom)) from MY_GEOMETRY_TABLE limit 1;
You should see all is well.
hth
charles
On Mar 2, 2010, at 9:26 AM, Sebastian Marsky wrote:
> hi,
> I'm trying to insert quite big MULTILINSTRING objects with about 1000 points. The INSERT-statement is in a form like:
> INSERT INTO MY_GEOMETRY_TABLE VALUES (1, 2, GeomFromText('MULTILINESTRING((11.5211 48.08109, [...],11.51651 48.08071))',4326));
> (first column being the PK, second an attribute (roadclass)).
> When I execute this one, no error occurs (even in the Postgres logs), but the 'geometry' column is just empty atferwards!
> I experimented a bit, and noticed that to the limit of about 170 points everything works, and above that, the problem shows up.
> So I wonder if there is any hard limit on number of points for a MULTILINESTRING? Or could something go wrong while parsing the string cause it exceeds some char array size?
> Sebastian Marsky
