[postgis-users] TIGER geocoder with Census 2009 shapefiles
Dan Putler dan.putler at sauder.ubc.ca
Tue Mar 2 08:20:42 PST 2010
Hi Kevin,
For non-disclosure reasons, the address range data has been
"fuzzed-up" (i.e., if the actual range is 901 to 957 Main St, they will
give the range as 901 to 961 Main St) so the match isn't exact. In
addition, if there are too few housing or business units on a road
segment, they do not include the address range for that segment, again
for non-disclosure reasons.
Dan Putler
On Tue, 2010-03-02 at 10:58 -0500, Kevin Galligan wrote:
> I actually bought an early access copy of the book.  I work in linux
> and have been playing around with different geocoders and the tiger
> files.  Most recently with a ruby geocoder, for no other reason than
> I'm trying to find one that is fairly complete and functional.
> Any idea how "production quality" this particular one is?  If its
> fairly high, I'll probably put some time in to get it working on
> linux.  I have the full 2009 tiger dataset on an EC2 block drive,
> waiting to import into a different database.
> Right now I'm using zip+4 data to get a rough geocode, which is good
> enough for what we're doing, but it only gets 92% of our non-PO Box
> data.  From my experience with the tiger data, it only adds a couple
> percent at most above that, but the geocoders I've used have been
> pretty hacky, so its possible that was the issue.  Also, some of them
> seem to not be concerned with stuff like matching "Main St" when
> you're looking for "Main Ln", which is pretty terrible.
> On the plus side, if there is major work going on with this geocoder
> (or any tiger geocoder), I have a huge national data volume that will
> help stress test the system.
> Recently I've been toying with USC's free geocoder project.  In some
> areas it actually gets about half of the data I previously could not,
> which is impressive.
> The really frustrating thing is, in general, the first 90% is
> cheap/free.  The next 3-4% is marginally expensive.  The rest is
> really pricey.
> Is there any idea how complete the tiger data is, and why there is
> this apparent lack of data in there?  I find it strange.  Some streets
> are just missing.  Stuff like that.
> Rambling.  Anyway, will take a look later.  Thoughts on the quality of
> the geocoder appreciated.
> -Kevin
> On Fri, Feb 26, 2010 at 11:52 PM, Paragon Corporation <lr at pcorp.us>
> wrote:
>         David,
>         As a matter of fact we've been working on that for chapter 10
>         of our
>         upcoming book and think we have it all working.  As a part of
>         the example
>         generation process for our chapter 10, we had to come up with
>         a way to load
>         the tables that works on both windows and Linux.
>          Unfortunately we haven't
>         had a chance to test the Linux loading approach, but is pretty
>         much a
>         parallel of the windows approach.
>         To do so we started out with Steve's code, added some
>         additional skeleton
>         tables and a database function that generates a command line
>         script for the
>         respective OS.  Hopefully it all makes sense from the readme
>         file we have
>         packaged.
>         We also changed one of the functions because there was an
>         error in it and
>         revised slightly to work with Tiger 2009 data.  You can
>         dowload our slightly
>         hacked version of Steve's code from our chapter 10 page.
>         Steve -- if you are listening we are hoping to remerge your
>         version with our
>         loader part and bring back into the PostGIS distribution as
>         part of PostGIS
>         1.5.1 or 2.0 release.
>         http://www.postgis.us/chapter_10
>         Leo and Regina
>         -----Original Message-----
>         From: postgis-users-bounces at postgis.refractions.net
>         [mailto:postgis-users-bounces at postgis.refractions.net] On
>         Behalf Of Dave
>         Fuhry
>         Sent: Friday, February 26, 2010 3:04 PM
>         To: PostGIS Users Discussion
>         Subject: [postgis-users] TIGER geocoder with Census 2009
>         shapefiles
>         I'm trying to set up the TIGER geocoder from
>         http://www.snowman.net/git/tiger_geocoder/ which is new and
>         aims to work
>         with the new TIGER shapefiles.  I'm trying with the 2009
>         shapefiles from
>         www2.census.gov/geo/tiger/TIGER2009/.
>         I'm not sure how to create the roads_local table (derived
>         closely from
>         completechain in the old version).  A join between edges and
>         addr?
>         Wondering if anyone can offer any direction.  A relevant
>         ticket is
>         http://trac.osgeo.org/postgis/ticket/135.  The out-of-date
>         file which used
>         to create the roads_local table is tables/roads_local.sql, in
>         the above
>         repository.
>         -Dave
>                                               Table "tiger.edges"
>           Column   |          Type          |
>         Modifiers
>          gid        | integer                | not null default
>         nextval('public.edges_gid_seq'::regclass)
>          statefp    | character varying(2)   |
>          countyfp   | character varying(3)   |
>          tlid       | bigint                 |
>          tfidl      | bigint                 |
>          tfidr      | bigint                 |
>          mtfcc      | character varying(5)   |
>          fullname   | character varying(100) |
>          smid       | character varying(22)  |
>          lfromadd   | character varying(12)  |
>          ltoadd     | character varying(12)  |
>          rfromadd   | character varying(12)  |
>          rtoadd     | character varying(12)  |
>          zipl       | character varying(5)   |
>          zipr       | character varying(5)   |
>          featcat    | character varying(1)   |
>          hydroflg   | character varying(1)   |
>          railflg    | character varying(1)   |
>          roadflg    | character varying(1)   |
>          olfflg     | character varying(1)   |
>          passflg    | character varying(1)   |
>          divroad    | character varying(1)   |
>          exttyp     | character varying(1)   |
>          deckedroad | character varying(1)   |
>          artpath    | character varying(1)   |
>          persist    | character varying(1)   |
>          gcseflg    | character varying(1)   |
>          offsetl    | character varying(1)   |
>          offsetr    | character varying(1)   |
>          tnidf      | bigint                 |
>          tnidt      | bigint                 |
>          the_geom   | public.geometry        |
>                                              Table "tiger.addr"
>          Column   |         Type          |
>         Modifiers
>         nextval('public.addr_gid_seq'::regclass)
>          tlid      | bigint                |
>          fromhn    | character varying(12) |
>          tohn      | character varying(12) |
>          side      | character varying(1)  |
>          zip       | character varying(5)  |
>          plus4     | character varying(4)  |
>          fromtyp   | character varying(1)  |
>          totyp     | character varying(1)  |
>          fromarmid | integer               |
>          toarmid   | integer               |
>          arid      | character varying(22) |
>          statefp   | character varying(2)  | not null
>         _______________________________________________
>         postgis-users mailing list
>         postgis-users at postgis.refractions.net
>         http://postgis.refractions.net/mailman/listinfo/postgis-users
Dan Putler
Sauder School of Business
University of British Columbia
