[postgis-users] How to join Two points(latitudes and langitudes) in postgis?
Michael Diener
m.diener at gomogi.com
Wed Mar 3 00:22:14 PST 2010
Hi Siddhesh
In qGIS the SRID must be properly defined when changed from -1 to draw on
screen. So you have to make sure your dataset SRID is properly defined.
Use the updategeometrySRID function to update your SRID from -1 to ####
here is an example
--usage
select updategeometrySRID('tableName','geometry_columnName','newSRID
number');
select updategeometrySRID('myTableName','geom',31255);
then your linestring should be drawn.
Cheers
michael
