[postgis-users] Missing postgis_config.h
Dan Ramage
dan at inlet.geol.sc.edu
Thu Mar 4 07:42:20 PST 2010
Mark,
Well, something odd has happened. I checked out PostGIS from svn, got it
built and installed.
After seeing your email just now, I tried building the 1.5 release again,
untarred it, ran configure and then make and it built this time.
Could something in the environment have changed when I ran the 'sh
autogen.sh' before running the configure in the svn checkout version?
Dan
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Thursday, March 04, 2010 9:31 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Missing postgis_config.h
Dan Ramage wrote:
> I'm trying to make the latest 1.5.0 as well as the 1.4.1 release,
> however I am getting an error of:
> "liblwgeom.h:18:31: error: ../postgis_config.h: No such file or directory"
> I see in the archives this was an issue with a previous version and the
> suggestion was to pull from the archive.
> Should I do the same as well, or might there be another issue?
Hi Dan,
postgis_config.h is generated by running configure. What does the output
of the configure command look like?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
